sumodos300
Utilizador Banido
boas
meti o vag com na lata do meu cunhado e deu nisto.
3 Faults Found:
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: 0000 0000
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
000 - -
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
na pag da ross tech n aparece o erro 17925...
ele keixava se k le acendia a luz do epc...
ibiza 1.2 de 2003
3 Faults Found:
P0571 - 35-00 - -
1 Fault Found:
000 - -
1 Fault Found:
1 Fault Found:
ibiza 1.2 de 2003
