boas...
fiz primeiro teste e deu estes erros
VAG-COM Version: Release 607.3-UD
Friday,24,October,2008,20:05:48
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 038 906 012 AH
Component: 1,9l R4 EDC 0200SG 2827
Coding: 00002
Shop #: WSC 26117
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Address 08: Auto HVAC
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D56
Coding: 00043
Shop #: WSC 06335
1 Fault Found:
00602 - Potentiometer On Positioning Motor for Footwell/Defroster Flap (G114)
30-00 - Open or Short to Plus
Address 15: Airbags
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 00104
Shop #: WSC 06335
Address 17: Instruments
Part No: 8D0 920 930 M
Component: KOMBI+WEGFAHRS. M73 D17
Coding: 00140
Shop #: WSC 46200
Part No: Ident
Component: Nr. Wegfahrs.:AUZ5Z0B1187003
Ident.-Nr. Wegfahrs.:AUZ5Z0B1187003
Address 25: Immobilizer
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06335
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
K será???
tentei tb por a trancar aos 20km/h, procurei no seach, mas dava um erro kualker de controller..... :evil:
tenho de passar pela Maia, lol
Kem poderá ajudar
Address 01: Engine
Coding: 00002
Shop #: WSC 26117
Readiness: N/A
Coding: 00043
Shop #: WSC 06335
1 Fault Found:
Address 15: Airbags
Coding: 00104
Shop #: WSC 06335
Coding: 00140
Shop #: WSC 46200
Part No: Ident
No Faults Found
Coding: 12865
Shop #: WSC 06335
4 Faults Found:
35-00 - -
35-00 - -
K será???
Kem poderá ajudar
