boas caros companheiros. hoje comprei um cabo vcds e fui ligar todo contente. o auto-scan deu isto:
6 Faults Found
4698 - Function Restriction due to Received Malfunction Value
U1113 00 [032] - Open or Short to Plus
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
4699 - Function Restriction due to Received Malfunction Value
U1113 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
9805 - Steering Column Control Module: No Communications
U0212 00 [032] - Check DTC Memory
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
4714 - Steering Column Control Module: No Communications
U0212 00 [032] - Open or Short to Plus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
4891 - EGR Valve (N18): Malfunction
P0403 00 [096] - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
mais abaixo:
1 Fault Found
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
1 Fault Found
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 12
Mileage: 10185 km
Time Indication: 0
Date: 2011.03.19
Time: 16:26:19
a kestão agora é esta. fui ao concessionario keixar-me k o carro estava a puxar mto à direita, possivelmente com os tais 5608 km...o k será k aconteceu?
e k raio de data é esta 9.6.2009 kdo o carro e de agosto de 2010?
abraços
6 Faults Found
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 32
Mileage: 5608 km
Date: 2009.09.06
Time: 18:00:00
mais abaixo:
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 12
Mileage: 10185 km
Time Indication: 0
Date: 2011.03.19
Time: 16:26:19
abraços
