[A3 8P] [A3 8P] by vsantos69 - fim de projecto
Marca:
Audi
Modelo:
A3 8P (Facelift)
Mês/Ano:
07/2009
Motor e Transmissão:
2.0TDI 140CV
Chassis:
Attraction 3 portas
Travões:
OEM
Jantes/Pneus:
A3/205x55x16
Extras base:
E0A = No special edition
7A0 = Without CD changer/CD player
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
6XJ = Exterior mirrors: automatically dimming,electrically adjustable/heated
5SL = Left exterior mirror: aspherical
5RU = Right exterior mirror: convex (large viewing field)
1KD = Disc brakes, rear
J0L = Battery 340 A (70 Ah)
1ZE = Disc brakes, front (Geomet D)
1AT = Electronic stabilization program (ESP)
3FA = Without roof insert (standard roof)
UA0 = Rear shock absorption
G37 = Front shock absorption
5MC = Decorative inserts
7X0 = Without park distance control - substituída
4R4 = Power windows with comfort operation andcircuit breaker
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A
0YE = Weight range 5 installation control only, no requirement forecast
L34 = Suspension range 34 installation control only, no requirement forecast
TG3 = 4-cylinder diesel engine 2.0 L unit 03L.A
3NZ = Rear seat bench unsplit, backrest split folding
8BD = Halogen headlight - substituída
U1A = Instrument insert with km/h speedometer,clock, tachometer and trip odometer
X3G = National sales program Portugal
1N3 = Speed-related variable steering assist (Servotronic)
1MR = Leather steering wheel
8Q1 = Headlight-range adjustment
9Q2 = Multi-function display/on-board computerwith check control
8Z4 = Moderate hot country
D91 = 4-cyl. turbo diesel 2 gineEZTD 03 kW (4V) TDI common rail; Base engine: TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
7Q0 = Without navigation device - substituída
C3L = Alloy wheel 6.5J x 16
7K0 = Without tire pressure warning light - substituída
4X3 = Side air bag front with curtain air bag
3L3 = Manual height adjustment for front seats
4KC = Side and rear windows in heat-insulatingglass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SA = Without additional engine guard
UG0 = Without hill hold control / hill descentcontrol / comfort driving assist
7MG = Emission standard EU5
QG1 = Service interval prolongation
4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
NOVOS (MOD's):
7X8 = Park distance control, front and rear with rear view camera
7Q2 = Navigation system with color screen;
QH1 = With voice control
8BP = Bi-functional headlight with gas discharge lamp;
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
7k6 = Flat tire indicator
7k8 = Tire pressure control, frequency 315 mhz, basic level version
7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection
UG1/UG4 = Hild Hold
Modificações efectuadas:
lampadas xénon em médios ---> substituido por bi-xénon OEM
Rádio "xinoca" com GPS, BT, leitura de CD's e DVD (ficheiros MP3, divx, etc...), USB, duas entradas para cartões de memória mini SD, TDT MPEG 2 - Substituido RNS-E
RNS_E 193 B/G (LED)- Done
TDT Mpeg 4 (comandado pelo volante) - Done
Câmara traseira a funcionar c/ o RNS-E - Done (funca automáticamente c/ MA, 06/08/2011) ----> Substituida pela OEM.
Botão p/ on/off park aid frente OEM iluminado... ... ... Done - 06/08/2011
Luzes de cortezia nas portas, branca e vermelha Done
Volante MF 3 braços com couro perfurado ... done
Camera MA OEM com linhas dinâmicas Done
Bi-xénon OEM (sistema completo, ou seja, mijas e niveladores automáticos) Done
Botão de abertura de portão electrico Done
Plafonier com lampadas de leitura individuais Done
RNS-E com SDS activo Done
Sensores OEM com OPS Done
Klimatronic com botões para bancos aquecidos Done
Botão Park assist Done (mas com uma utilização diferente - liga desliga o TDT :D)
TPMS Done
Optical Parking System (OPS) Done
Camera de MA OEM + OPS (ou como lhe chama a Audi - sensores ópticos :D) Done
Botão para mala e tampa de combustível ... DONE
Alarme OEM ... DONE
Hill Hold ... DONE
Led's na Matrícula ... DONE
TPMS - RESET no CB ... DONE
Assistente de máximos ... DONE
Molas (suspensão) S-line OEM ... DONE
Espelhos Rebatíveis (2012) ... DONE
Modificações pr€vistas:
Uns "sofás" Récaro ou de A5 :D... (para quando houver guito ou um bom negócio)
Jantes 17'' S-line OEM ...
Side Assist ... Será?
Lane assist ... Será?
Park assist ... Será?
bi-xénon direccional ... (a pensar)
Photos do que está feito (e outras que foram mudadas):
-Páginas 6, 8, 12, 18, 20, 23, 24 e 26.
- Pág. 29 - #435 - como activar o TPMS no CB
Re: A3 8p 140 cv by vsantos69
com este frio bem que podias ter ido pagar o café a repsol, lá para as 2h devo lá estar :D
bota fotos com força mas é...
Calma pessoal, estou a tomar conta da "piquena" e de seguida vou ao martini da praxe para estar inspirado para o almoço e, claro, para as fotos.:D:D:D:assobio::assobio::assobio:
VIA3
Ontem não dava, trabalho em Lisboa durante a semana e estava a matar saudades ;)
o que falhou?
carregas a imagem, copias o direct link, e copias para a janela de inserir imagem.. ;)
redimensiona as imagens para 640x480 e depois insere o link directo do imageshack ;)
