Boa Tarde a Todos
Estou com falhas intermitentes no A6 C6 a nível de Direção Assistida, mesmo com um bomba de D.A. recondicionada e o liquido está no nível certo.
O problema manifesta-se essencialmente em curvas a uma velocidade lenta, sendo que passados uns segundos volta a Direção Assistida.
VCDS acusa os seguintes erros:
Part No SW: 4F0 910 401 F HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number:
Coding: 0011772
6 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 001 - Electrical Fault - MIL ON
Freeze Frame:
RPM: 882 /min
Torque: 109.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 35.9 %
Temperature: 17.1°C
Bin. Bits: 10110000
17022 - Throttle Body Actuator Bank 1 (J338)
P0638 - 002 - Implausible Signal
Freeze Frame:
RPM: 0 /min
Torque: -195.0 Nm
Speed: 0.0 km/h
Voltage: 12.39 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Mass Air / Rev.: 0.0 mg/str
Voltage: 0.000 V
17953 - Throttle Valve Controller
P1545 - 001 - Malfunction
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Voltage: 0.000 V
18628 - Oxygen (Lambda) Sensor B1 S1
P2196 - 001 - Signal too High (Rich)
Freeze Frame:
RPM: 2058 /min
Torque: 503.1 Nm
Speed: 68.3 km/h
Duty Cycle: 54.8 %
Mass Air / Rev.: 1022.3 mg/str
(no units): 0.60
(no units): 0.0
Bin. Bits: 10001001
17586 - Linear O2 Sensor; Pump Current
P1178 - 000 - Open Circuit
Freeze Frame:
RPM: 1575 /min
Torque: 319.8 Nm
Speed: 68.3 km/h
Duty Cycle: 35.9 %
Mass Air / Rev.: 1216.1 mg/str
(no units): 0.80
(no units): 8.0
Voltage: 0.000 V
16619 - Boost Pressure
P0235 - 001 - Regulation Range not Reached
Freeze Frame:
RPM: 1722 /min
Torque: 226.2 Nm
Speed: 75.0 km/h
Absolute Pres.: 1479.0 mbar
Absolute Pres.: 999.6 mbar
Mass Air / Rev.: 1145.6 mg/str
Temperature: 18.9°C
Duty Cycle: 71.0 %
Readiness: 0 0 0 0 0
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 351EI047502365
Coding: 0000007
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
Subsystem 2 - Serial number: 00000000014206
Subsystem 3 - Serial number: 0118.05.040000000100010363ÿ
Subsystem 4 - Serial number: 010363ÿ
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 254465 km
Time Indication: 0
Date: 2021.02.08
Time: 17:29:05
00658 - Control Head
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 161
Mileage: 254241 km
Time Indication: 0
Date: 2021.01.29
Time: 17:23:42
Freeze Frame:
Bin. Bits: 001
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 H
Component: KLIMABETAETIGUNGH11 0060
Revision: 00000021 Serial number: 00000000018398
Coding: 0000150
1 Fault Found:
00739 - Coolant Circulation Pump (V50)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 254215 km
Time Indication: 0
Date: 2021.01.27
Time: 14:14:03
Freeze Frame:
Temperature: 77.0°C
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804430015A
Coding: ECFE53CC1B3504
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 158
Mileage: 254215 km
Time Indication: 0
Date: 2021.01.27
Time: 16:10:46
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000014063
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1405040258
Coding: 344630393135313035442056413031343035303430323538
1 Fault Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 254191 km
Time Indication: 0
Date: 2021.01.18
Time: 12:37:33
Sugestões?
Coding: 0011772
6 Faults Found:
Freeze Frame:
RPM: 882 /min
Torque: 109.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 35.9 %
Temperature: 17.1°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 0 /min
Torque: -195.0 Nm
Speed: 0.0 km/h
Voltage: 12.39 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Voltage: 0.000 V
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 12.01 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Voltage: 0.000 V
Freeze Frame:
RPM: 2058 /min
Torque: 503.1 Nm
Speed: 68.3 km/h
Duty Cycle: 54.8 %
(no units): 0.60
(no units): 0.0
Bin. Bits: 10001001
Freeze Frame:
RPM: 1575 /min
Torque: 319.8 Nm
Speed: 68.3 km/h
Duty Cycle: 35.9 %
(no units): 0.80
(no units): 8.0
Voltage: 0.000 V
Freeze Frame:
RPM: 1722 /min
Torque: 226.2 Nm
Speed: 75.0 km/h
Temperature: 18.9°C
Duty Cycle: 71.0 %
Coding: 0000007
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 146
Mileage: 254465 km
Time Indication: 0
Date: 2021.02.08
Time: 17:29:05
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 161
Mileage: 254241 km
Time Indication: 0
Date: 2021.01.29
Time: 17:23:42
Freeze Frame:
Bin. Bits: 001
Coding: 0000150
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 158
Mileage: 254215 km
Time Indication: 0
Date: 2021.01.27
Time: 14:14:03
Freeze Frame:
Temperature: 77.0°C
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 158
Mileage: 254215 km
Time Indication: 0
Date: 2021.01.27
Time: 16:10:46
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 254191 km
Time Indication: 0
Date: 2021.01.18
Time: 12:37:33
Sugestões?
