{Steering Wheel Electronics}
Control Module Coding
Select 16 (Steering Wheel Electronics)
Coding -> Function 07
00?xxxx: Transmission
0 - Manual Transmission
1 - Automatic Transmission
00x?xxx: Steering Wheel
0 - 3-Spoke, w/o Tiptronic, w/o Multi-Function
1 - 3-Spoke, with Tiptronic, w/o Multi-Function
2 - 4-Spoke Multi-Function (with Radio Control)
3 - 4-Spoke Multi-Function (with Radio/Telephone Control)
4 - 4-Spoke Multi-Function (with Radio/Telephone/Voice Control)
00xx?xx: Tiptronic/Heating
+1 - Tiptronic on Steering Wheel
+2 - Steering Wheel Heating
00xxx?x: Cruise Control/Board Computer
0 - no Board Computer, no Cruise Control
1 - Board Computer, no Cruise Control
2 - no Board Computer, Cruise Control
4 - Board Computer, Cruise Control
00xxxx?: Rear Wiper
0 - w/o Rear Wiper
1 - with Rear Wiper
Activating Cruise Control on a new ECU (DBW):
Factory fresh ECU's often come with cruise control de-activated. If this is the case, there will not be a letter "G" in the Component field of VAG-COM when connected to the Engine.
[Select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
After doing this procedure, there should be a letter "G" in the Component field.
Then change the 16 – Steering Wheel code – as listed above.
