Amigos,
Digam de vossa justiça deste longo testemunho.
Sunday,23,October,2011,22:33:44:46862
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E63A360189 Mileage: 175260km/108901miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JT
Component: 1,9l R4 EDC G400SG 1572
Coding: 00002
Shop #: WSC 63351
VCID: 72E0D89652F5378C
WAUZZZ8E63A360189 AUZ6Z0C0071938
3 Faults Found
17996 - Engine Mount Solenoid Valves (N144/N145): Open Circuit
P1588 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
VCID: E5CA33CA133B5034
1 Fault Found
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2A5000F6BAA53F4C
1 Fault Found
00710 - Defroster Flap Positioning Motor (V107)
41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0416
Coding: 01011
Shop #: WSC 63251
VCID: 356A238A631B60B4
1 Fault Found
00988 - Lamp for Brake Light; Right (M10)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 366824867E1D6BAC
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63251
VCID: 3E783CA6562DA3EC
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00000
Shop #: WSC 00006
1 Fault Found
01176 - Key
07-10 - Signal too Low - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E HIGH EU H72 0650
Revision: 04S Serial number: AUZBZ7F1151793
Coding: 0309717
Shop #: WSC 06325 000 00000
VCID: 254AF3CAD3BB1034
9 Faults Found
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 225
Time Indication: 0
Date: 2010.07.28
Time: 08:14:55
Freeze Frame:
Voltage: 11.70 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 225
Time Indication: 0
Date: 2002.02.20
Time: 00:00:30
Freeze Frame:
Voltage: 11.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
00857 - CD Changer Unit (R41)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:53:00
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Time Indication: 0
Date: 2008.07.06
Time: 13:29:46
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Date: 2010.02.24
Time: 08:44:50
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Date: 2008.06.23
Time: 09:18:52
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:20
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 07008
Shop #: WSC 63251
VCID: 71E2D79A57F30C94
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0003
1 Fault Found
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 040C8E4E7841093C
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309717
9 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 225
Time Indication: 0
Date: 2010.07.28
Time: 08:14:55
Freeze Frame:
Voltage: 11.70 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 225
Time Indication: 0
Date: 2002.02.20
Time: 00:00:30
Freeze Frame:
Voltage: 11.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:53:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Time Indication: 0
Date: 2008.07.06
Time: 13:29:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Date: 2010.02.24
Time: 08:44:50
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Date: 2008.06.23
Time: 09:18:52
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:20
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00114
Shop #: WSC 63351
VCID: 438E4D523DCFCE04
Alguns ja descobri (acho eu):
Problema: apoios de motor ou babanço de oleo na EGR
G70 Datasheet
Problema: MAF foi ao ar ???
Problema:
http://www.audipt.com/f82/[ajuda]-charge-pressure-control-negative-deviation-[resolvido]-94378/
turbo boost control solnoid (N75)
Obrigado pela ajuda !!!
69 75 76 77
Coding: 00002
Shop #: WSC 63351
3 Faults Found
Coding: 04255
Shop #: WSC 06435
1 Fault Found
Coding: 00000
Shop #: WSC 63351
1 Fault Found
Coding: 01011
Shop #: WSC 63251
1 Fault Found
Coding: 0010602
Coding: 00042
Shop #: WSC 63251
Coding: 00000
Shop #: WSC 00006
1 Fault Found
01176 - Key
Coding: 0309717
9 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 225
Time Indication: 0
Date: 2010.07.28
Time: 08:14:55
Freeze Frame:
Voltage: 11.70 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 225
Time Indication: 0
Date: 2002.02.20
Time: 00:00:30
Freeze Frame:
Voltage: 11.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:53:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Time Indication: 0
Date: 2008.07.06
Time: 13:29:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Date: 2010.02.24
Time: 08:44:50
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Date: 2008.06.23
Time: 09:18:52
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:20
Coding: 07008
Shop #: WSC 63251
Part No: 8E1959801B
Part No: 8E1959802B
1 Fault Found
Coding: 00060
Shop #: WSC 63351
Coding: 0309717
9 Faults Found
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 225
Time Indication: 0
Date: 2010.07.28
Time: 08:14:55
Freeze Frame:
Voltage: 11.70 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 10
Reset counter: 225
Time Indication: 0
Date: 2002.02.20
Time: 00:00:30
Freeze Frame:
Voltage: 11.70 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:53:00
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 204
Time Indication: 0
Date: 2008.07.06
Time: 13:29:46
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Date: 2010.02.24
Time: 08:44:50
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
Date: 2008.06.23
Time: 09:18:52
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Time Indication: 0
Date: 2008.06.21
Time: 00:52:20
Coding: 00114
Shop #: WSC 63351
G70 Datasheet
Problema:
