Boas, fiz o scan com o vag e deram me os seguintes erros
2 Faults Found
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Possible Symptoms
* Temperature flap not moving or incorrect position
Possible Causes
* Temperature flap stiff
* Wiring defective
* Potentiometer/Actuator for Temperature Flap Right (G221) defective
Possible Solutions
* Perform basic setting
* Check temperature flap movement, if necessary use grease/oil
* Check Wiring
* Replace Potentiometer/Actuator for Temperature Flap Right (G221)
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes
* Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
* Positioning Air Flow Flap Positioning Motor (V71) blocked
* Positioning Air Flow Flap Positioning Motor (V71) faulty
Possible Solutions
* Check Air Flow Flap Positioning Motor (V71)
o See Measuring Value Blocks (MVB)
o Perform Output Test
o Perform Basic Setting
* Check/Repair Wiring and Connectors
ja estive a ver na net o que querem dizer os erros mas queria saber realmente o que se passa porque so com estas descriçoes nao percebo mt bem.
alguem ja teve estes erros? o que k fizeram para resolver isto?
obrigado e aguardo a vossa ajuda.
2 Faults Found
Possible Symptoms
Possible Causes
* Wiring defective
Possible Solutions
* Check Wiring
Possible Causes
Possible Solutions
