ajuda codigos
ola pessoal venho pedir ajuda para ler alguns codigos de uma a4 b6 de um amigo que tenho estado a ver se resolvo isto aconteceu praticamente quando ficou sem bateria..
Wednesday,15,December,2010,22:19:01:46862
VCDS Version: Beta 912.0
Data version: 20091201
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 219100km/136142miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 JQ
Component: 1,9l R4 EDC 0400SG 1570
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E63A204623 AUZ6Z0B0296490
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-00 - Open or Short to Plus
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0011602
Shop #: WSC 63351 000 00000
2 Faults Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
000 - - - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC 00000
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 00000
Shop #: WSC 00006
Part No: 04623
Component: AUZ6Z0B0296490
Address 37: Navigation Labels: Redir Fail!
Part No: 8E0 035 192 B
Component: RNS 4.2 H06 BNO 0105
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BA
Component: Komfortgerát TA7 1310
Coding: 06976
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
4 Faults Found:
01562 - Right Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
00955 - Key 1
01560 - Passenger Door
Address 56: Radio Labels: Redir Fail!
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 31968
agora tem tambem um problema q é a scova traseira comecar a trabalhar sosinha e por veses parar a meio ou num dos lados.. tem tambem problemas na porta frente dta e tras direita q quando se abre nao acende as luzes interior e nao da indicaçao de porta aberta..bom na da frente ja resolvi era no fecho onde liga a ficha e onde tem o switch tava com mau contacto e consegui resolver agora falta tirar a de tras para ver o que é.. em relacao ao airbag fiz como esta descrito aqui num topico q procurei de um user a esplicar como se fazia com vag tipo ir aos canais onde tem o erro e tipo codificar..agora to a esprimentar para ver se ainda acende.. quanto ao resto nao sei o que é.. se me poderem dizer algo agradecia...
ha uma outra coisa..a carrinha tem rns plus.. acontece que antes de ficar sem bateria..no digito onte tem as horas aparecia ao lado um simbulo tipo parecia uma antena tipo como nos telemoveis ou gps.. e agora isso dezapareceu sabem o que isso é? tera a ver com o gps ou radio?
e ja agora eu tava a tentar entrar com vag no radio para tentar ver se avia forma de aceder a algumas definicoes que disse se algo sobre isso..mas no vag pede me la um codigo primeiro..esse codigo é o codigo do radio ou é outro que tem a ver com o vag para se poder aceder?
obrigado
pessoal..venho dizer que jaq dei com algumas coisas..a parte do airbag ficou resolvido e da escova traseira tambem..tirei o motor fora e reparei que estava cheio de agua na parte de dentro electrica sequei tudo e meti wd40 para dentro montei e ficou impec..ja nao liga sozinho..:) agora se me poderem ajudar na parte do rns como posso aceder as comf atraves de vag..é que queria saber e ver se conseguia por novamente aquele simbolo q parece uma antena no digito ao lado das horas..
No rns podes ir ao módulo de RADIO ou NAVIGATION...
Quanto a essa antena, segundo se consta é um extra que permite acertar as horas com recurso a satélites.. Se desapareçeu pode ter sido algo no CB que desmarcaste.. digo eu... Ou tenta no módulo INSTRUMENTS...
