ajuda em diagnostico
boas pessoal. fui dar uma volta com o meu carro e com o vag-com ligado para ver que resultados dava pk ele tem me puxado mal. o resultado foi este. alguem me sabe dizer se ta tudo em ordem?
Monday,20,February,2012,18:57:41:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
Adaptation Channel 008:
Stored value 1
Unlock Message - Key
Unlocked
Key
Blink
Tuesday,28,February,2012,23:08:30:10074
Address 01: Engine (03G 906 018 DH)
23:08:26 Group 001
805 /min RPM
5.1 mg/str Inj. Quantity
3.8°KW Idle Stabilization
85.0°C Temperature
23:08:26 Group 002
799 /min RPM
0.0 % Duty Cycle
00001000 Bin. Bits
85.0°C Temperature
23:08:26 Group 003
796 /min RPM
280.0 mg/str Mass Air / Rev.
284.1 mg/str Mass Air / Rev.
50.2 % Duty Cycle
Tuesday,28,February,2012,23:32:27:10074
23:32:24 Group 001
802 /min RPM
4.9 mg/str Inj. Quantity
91.0°C Temperature
23:32:24 Group 002
808 /min RPM
0.0 % Duty Cycle
00001000 Bin. Bits
91.0°C Temperature
23:32:24 Group 003
803 /min RPM
283.2 mg/str Mass Air / Rev.
50.4 % Duty Cycle
pessoal ja fiz um auto scan e deu me alguns erros esquesitos. ou seja nao percebo nada.lol
alguem me pode ajudar?
Saturday,03,March,2012,16:59:55:10074
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
VIN: WAUZZZ8P37A044790 Mileage: 115400km/71706miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Part No SW: 03G 906 018 DH HW: 03G 906 018 DH
Component: R4 2.0l PPD1.2 G 1185
Revision: --H22--- Serial number: AUX7Z0F6FNV09K
Coding: 0000072
Shop #: WSC 00116 261 89348
VCID: 6ED7CA8B0257
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73E1DBFF6975
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
Component: KlimavollautomatH18 0300
Revision: 055047 Serial number: 8P0820043P
VCID: 397D29D70B99
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006024234
Coding: E5885F078214100000000000000000000009FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408B44336843
Subsystem 1 - Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00412717
Shop #: WSC 06314
4 Faults Found:
01493 - Bulb for Blinkers; Front Left (M5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 18
Reset counter: 243
Mileage: 111222 km
Time Indication: 0
Date: 2011.12.18
Time: 13:31:00
Freeze Frame:
ON
Voltage: 11.35 V
ON
ON
OFF
OFF
OFF
00061 - Footwell Lights
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 108004 km
Time Indication: 0
Date: 2011.10.10
Time: 00:35:00
Freeze Frame:
ON
Voltage: 12.30 V
ON
ON
OFF
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 63
Reset counter: 237
Mileage: 109721 km
Time Indication: 0
Date: 2011.11.24
Time: 12:51:00
Freeze Frame:
ON
Voltage: 11.60 V
ON
ON
OFF
OFF
OFF
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 245
Mileage: 115041 km
Time Indication: 0
Date: 2012.02.25
Time: 16:13:00
Freeze Frame:
OFF
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H12 3720
Revision: 91H12372 Serial number: 0037W0G00M2$
Coding: 0070612
VCID: 47995F2F4D6D
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H34 0070
Coding: 0000042
VCID: 418D41376349
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 931 HW: 8P0 920 931
Component: KOMBIINSTR. VDO H18 0560
Revision: D0H18002 Serial number: 2246F002021739
Coding: 0004118
Shop #: WSC 00011 888 96745
VCID: F0EB54F39863
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 320010671680F6
Coding: 3D0F0F4207000100
VCID: 2E570A8BC2D7
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 115041 km
Time Indication: 0
Date: 2012.02.25
Time: 16:13:33
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H18002 Serial number: AUX7Z0F6FNV09K
Shop #: WSC 00138 261 94082
VCID: F0EB54F39863
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000088
VCID: 408B44336843
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.078 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346318E32CFB
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 188000186D288505488A016300
VCID: 3E773ACB12B7
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH27 0160
Revision: 00005 Serial number: 30659635456365
Shop #: WSC 00000 000 00000
VCID: F0EB54F39863
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000088
VCID: 418D41376349
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H58 0460
Revision: 23S Serial number: AUZ5Z4F6221970
Coding: 0001001
Shop #: WSC 65286 004 00000
VCID: EFE9578F855D
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 115407 km
Time Indication: 0
Date: 2012.03.03
Time: 16:58:18
Freeze Frame:
Bin. Bits: 10000
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 00067824820620
Coding: 0000003
VCID: 3C7330C304AB
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CFD1
Os únicos erros que tens e de luzes e outro no climatronic
Mas são erros esporádicos verifica todas as luzes assim como as luzes na zona dos pés
Depois apaga anda com ele uns dias e volta a fazer um scan
eu tenho leds. deve ser por isso. no radio tambem diz qualquer coisa mas tambem deve ser por ter o XCARLINK. desculpa a minha ignorancia... mas como se apaga os erros? (ainda sou iniciante):green:
