ajuda erros vag-com
boas pessoal recentemente adquiri o cabo vag-com e fiz o scan para ver os erros e o resultado nao foi nada
agradavel vou por aqui o resultado:o:
Saturday,04,May,2013,18:53:15:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 284240km/176618miles
Part No: 038 906 018 BA
Component: 1,9l R4 EDC 32AG 1812
Coding: 00001
Shop #: WSC 06020
VCID: 56A9F7FCB21C42E
3 Faults Found:
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
18034 - Powertrain Data Bus
P1626 - 35-10 - Missing Message from TCU - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 E
Component: ABS/EDS 20 IE CAN 0001
Coding: 13304
Shop #: WSC 06435
VCID: 336F6E68012E776
1 Fault Found:
01312 - Powertrain Data Bus
37-00 - Faulty
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A3 KLIMAVOLLAUTOMAT_D75
Coding: 03143
Shop #: WSC 06313
VCID: 29538C00D3E23D6
2 Faults Found:
01273 - Fresh Air Blower (V2)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: Redir Fail!
Part No: 8L0 959 655 C
Component: Airbag 6 Audi D01
Coding: 00004
Shop #: WSC 06313
VCID: 3E794F5C3A6CAAE
No fault code found.
Address 17: Instruments Labels: 8L0-919-xxx-17.lbl
Part No: 8L0 919 880 B
Component: AB-KOMBIINSTR. VDO D11
Coding: 06140
Shop #: WSC 00261
VCID: 39735C4023428D6
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0V0235488
IMMO-IDENTNR: AUZ7Z0V0235488
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk
Coding: 10184
Shop #: WSC 65535
VCID: 1123C4E05B72656
End -----------------------------------------------------------------
ja fiz clear all dtc e volta a aparecer
alguem me pode ajudar a decifrar ???
cump. e boas curvas
elimina os erros, da uma volta boa com o carro, e ve se voltaram, podem ser apenas erros antigos, que ja estão resolvidos, mas nao foram apagados ;)
