Ola a todos!! estou com um problema num dos meus carros (audi a6 2.5 tdi 150cv de 1998). o mesmo nao pega.
liguei o vagcom fiz o diagnostico e deu isto:
Controller: 4B0 907 401 K 2
Component: 2.5l/4VT EDC 0000SG D50
Coding: 01002
Shop #: WSC 02325
5 Faults Found:
18259 - Powertrain Data Bus: Missing Message from ABS Controller
P1851 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
00575 - Intake Manifold Pressure -------------------------pressao no colector de admissao
11-10 - Control Limit Not Reached - Intermittent -------------- contROLO NAO atingiu limite
00546 - Data wiring faulty ------------------------------- fiaçao de cabos com defeito
49-10 - No Communications - Intermittent
00523 - Intake Air Temp Sensor (G42) sensor de temperatura do air de Admissao
30-10 - Open or Short to B+ - Intermittent
Readiness: N/A
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 P
Component: A6-Klimavoll
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 919 880 G
Component: C5-KOMBIINSTR. VDO D10
Coding: 05160
Shop #: WSC 00000
IMMO-IDENTNR: AUZ7Z0W0763381
No fault code found.
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 E
Component: Zentralverrieg.,DWA D35
Coding: 04683
Shop #: WSC 00000
13 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
09-00 - Adaptation Limit Surpassed
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01562 - Right Rear Door
59-00 - Can't Unlock
60-10 - Won't Safe - Intermittent
61-00 - Won't De-Safe
01574 - Alarm triggered by Door Contact Switch: Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch: Left Rear
35-00 - -
Address 36 -------------------------------------------------------
Controller: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
6 Faults Found:
01377 - Ultra Sonic Sensor for Alarm System: Left (G170)
27-00 - Implausible Signal
01378 - Ultra Sonic Sensor for Alarm System: Right (G171)
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00005
Shop #: WSC 02325
Alguem me pode dizer como corrijo estes erros?
nao sei se é na parte de login eu nao percebo mto disto. Alem disso nem sei como faço login nem para quê necessito de fazer login. é para ter acesso a mais funcionalidades? Peço ajuda urgente poruqe tenho o carro parado sem andar e nao sei o que fazer... obrigado a todos.
Coding: 01002
Shop #: WSC 02325
5 Faults Found:
Readiness: N/A
Coding: 05160
Shop #: WSC 00000
Coding: 04683
Shop #: WSC 00000
13 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 00001
Shop #: WSC 02325
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00005
Shop #: WSC 02325
