Optei por comprar um cabo e ligar o VAG-com ao carro com a versão 3.11 e gostaria de saber o que poderão significar os erros. Como tal gostaria de pedir a vossa ajuda.
O log é apresentado em baixo.
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 8N0 906 018 Q
Component: 1.8L R4/5VT G01 0004
Coding: 05500
Shop #: WSC 00001
2 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 D
Component: ESP 20 CAN V006
Coding: 23049
Shop #: WSC 01236
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to B+ - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8N1 920 880 C
Component: KOMBI+WEGFAHRS. M73 D07
Coding: 00044
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:AUZ5Z0Y2212199
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
Address 35 -------------------------------------------------------
Controller: 8N8 962 267
Component: Zentralverrieg.,DWA D04
Coding: 04712
Shop #: WSC 01236
10 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch: Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - Key 2
01560 - Passenger Door
59-00 - Can't Unlock
60-10 - Won't Safe - Intermittent
61-00 - Won't De-Safe
End -------------------------------------------------------
Desde já obrigado pela ajuda.
Coding: 05500
Shop #: WSC 00001
2 Faults Found:
Coding: 23049
Shop #: WSC 01236
Coding: 00040
Shop #: WSC 01236
1 Fault Found:
Coding: 00044
Shop #: WSC 00000
1 Fault Found:
Coding: 04712
Shop #: WSC 01236
10 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
