Alguem me sabe do que e proveniente estes erros?
Tuesday,17,December,2013,14:46:24:55062
VCDS Version: Release 11.11.4
Address 01: Engine Labels: 03L-906-022-CAG.clb
Control Module Part Number: 03L 906 022 JM HW: 03L 906 022 B
Component and/or Version: R4 2,0L EDC H01 3173
Software Coding: 0104002C18072118
Work Shop Code: WSC 06335 000 00000
ASAM Dataset: EV_ECM20TDI03L906022JM A01005 (AU48)
VCID: 79F25A8EF80E44D066B
1 Fault Found
5262 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [040] - Short to GND
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 33
Mileage: 177599 km
Date: 2013.12.16
Time: 15:52:25
Readiness: 0 1 0 0 0
Tuesday,17,December,2013,14:47:11:55062
Address 08: Auto HVAC Labels: Redir Fail!
Control Module Part Number: 8T1 820 043 AB HW: 8T1 820 043 AB
Component and/or Version: KLIMA 3 ZONEN H06 0140
Software Coding: 34000000
VCID: 71E262AEA87E0C90DEB
1 Fault Found
00710 - Defroster Flap Positioning Motor (V107)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 176454 km
Time Indication: 0
Date: 2013.11.17
Time: 15:26:28
Freeze Frame
Voltage: 13.80 V
Temperature: 9.0∞C
Temperature: 9.0∞C
Count: 10000
Count: 9419
Bin. Bits: 01000000
Bin. Bits: 10000011
1 Fault Found
Freeze Frame
Fault Priority: 2
Fault Frequency: 33
Mileage: 177599 km
Date: 2013.12.16
Time: 15:52:25
1 Fault Found
Freeze Frame
Fault Priority: 3
Fault Frequency: 1
Reset counter: 11
Mileage: 176454 km
Time Indication: 0
Date: 2013.11.17
Time: 15:26:28
Freeze Frame
Voltage: 13.80 V
Temperature: 9.0∞C
Temperature: 9.0∞C
Count: 10000
Count: 9419
Bin. Bits: 01000000
Bin. Bits: 10000011
