Boas, tenho este erros na minha argolas.
Já alguém teve estes problemas ou erros relacionados com o sistema Comfort?
Code:
Monday,26,December,2011,10:41:06:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8EXXXXXXXXX Mileage: 123370km/76658miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC G000SG 7420
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 05572 843 13298
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H05 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 01008 261 92749
1 Fault Found:
00778 - Steering Angle Sensor (G85)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFFB0
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BK
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00001
3 Faults Found:
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
09-00 - Adaptation Limit Surpassed
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10001
Shop #: WSC 00001
1 Fault Found:
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001LRA4
Coding: 0033622
Shop #: WSC 06325 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 03042
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006141
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
012 - Electrical Fault in Circuit
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
Address 46: Central Conv. Labels: None
Part No: 8E0 959 433 BK
Component: Komfortgerát TA7 2431
Coding: 07024
Shop #: WSC 00001
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
4 Faults Found:
00956 - Key 2
35-00 - -
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01005
Shop #: WSC 06325
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 D HW: 8P0 862 335 D
Component: FSE_255x BT H18 0050
Revision: 00000001 Serial number: 00000000162385
Coding: 0000511
