Boas pessoa.
Tive a fazer a minha boneca auto-scan, obtive o seguinte resultado, o que posso saber desta leitura? fiquei assustado com a quantidade de erros.
Alguém me pode ajudar?
Saturday,16,July,2011,17:30:27:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Part No: 038 906 018 S
Component: 1,9l R4 EDC 00SG 1614
Coding: 00002
Shop #: WSC 06325
VCID: 2647F2ABE877
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
00777 - Accelerator Position Sensor (G79)
27-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB79A4BF0A7
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
35-00 - -
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04143
Shop #: WSC 06325
VCID: 295DF997F969
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 C
Component: Airbag 7 Audi 0303
Coding: 00106
Shop #: WSC 06325
VCID: 366722EB38D7
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 860 E
Component: B5-KOMBIINSTR.UN4 D01
Coding: 00040
Shop #: WSC 32719
VCID: 326F1EFBD4BF
Part No: IMMO
Component: IDENTNR: AUZ8Z0V6220193
IMMO-IDENTNR: AUZ8Z0V6220193
1 Fault Found:
01176 - Key
07-10 - Signal too Low - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 E
Component: ZV-Pumpe D03
Coding: 00000
Shop #: WSC 65535
VCID: 56A7826B9897
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
Cump...
Coding: 00002
Shop #: WSC 06325
VCID: 2647F2ABE877
2 Faults Found:
P1570 - 35-00 - -
Readiness: N/A
Shop #: BB 24548
VCID: 5EB79A4BF0A7
1 Fault Found:
35-00 - -
Coding: 04143
Shop #: WSC 06325
VCID: 295DF997F969
Coding: 00106
Shop #: WSC 06325
VCID: 366722EB38D7
1 Fault Found:
Coding: 00040
Shop #: WSC 32719
VCID: 326F1EFBD4BF
Part No: IMMO
1 Fault Found:
01176 - Key
Coding: 00000
Shop #: WSC 65535
VCID: 56A7826B9897
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Cump...
