Autoscan...Help :(
Boas pessoal é o seguinte, o carro funcionava bem desde ontem a noite... hoje peguei nele e fiquei sem fecho central, luzes interiores menos pés e portas, sem radio... E fiz um scan ao carro e aparece estes erros, mas vi no Wiki alguns que me dá fusíveis, mas o estranho que os fusíveis estão bons tanto no interior como no motor... que acham?:S:S
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Component: KlimavollautomatH19 0360
Revision: 084132 Serial number: 8P0820043AC
Shop #: WSC 06314 000 00000
VCID: 6DDAD5300DED
No fault code found.
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006504909
Coding: E5885B178014100000000000000000000008FE175C0300
Shop #: WSC 06314 000 08192
VCID: 40845C846AFF
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
5 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 4
Reset counter: 210
Mileage: 67978 km
Time Indication: 0
Date: 2011.04.20
Time: 15:47:00
Freeze Frame:
OFF
Voltage: 12.95 V
OFF
OFF
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 210
Mileage: 67978 km
Time Indication: 0
Date: 2011.04.20
Time: 16:05:00
Freeze Frame:
OFF
Voltage: 12.80 V
OFF
OFF
OFF
OFF
OFF
02071 - Local Databus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 67978 km
Time Indication: 0
Date: 2011.04.20
Time: 15:47:00
Freeze Frame:
OFF
Voltage: 12.95 V
OFF
OFF
OFF
OFF
OFF
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 210
Mileage: 67978 km
Time Indication: 0
Date: 2011.04.20
Time: 15:50:00
Freeze Frame:
OFF
Voltage: 12.95 V
OFF
OFF
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 67978 km
Time Indication: 0
Date: 2011.04.20
Time: 15:47:00
Freeze Frame:
OFF
Voltage: 12.95 V
OFF
OFF
OFF
OFF
OFF
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106B230BCB
Coding: BD0F074207000100
VCID: 2F660F38C761
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 67978 km
Time Indication: 0
Date: 2011.04.20
Time: 15:50:39
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H05 0070
Coding: 9880202002586D298505488AC677
VCID: 3F865F781701
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
00352 - Terminal 30A
011 - Open Circuit - Intermittent
Eu foi a bomba de vacuo
Partiu o imãn e as palas
Resultado Sem feicho central
tive de desativar a bomba pelo o vag com porque se a desligo nao consigo abrir os vidros e fico sem luz nos plafoniers
Acho que vo mesmo comprar nova na audi porque assim o menos ja nao tenho problemas
Os 8P não têm bomba para o fecho centralizado..
Apenas disse q os 8p não têm bomba para não acontecer virem para aqui users com 8ps com o mesmo problema do marco e lerem o teu post e ficarem a pensar q o problema é da bomba.. O meu post anterior foi apenas para clarificar ;)
Sim verdade, mas o meu problema foi de um dia, estranho mesmo estranho... fusíveis bons ate no motor, e sem luz sem fecho central, sem climatronic... e depois activou sozinho o meu carro esta muito a frente... lool
Deve ter sido um bug na centralina o uma cena do genero
aqui a dias tive o conta kilomtros marado a agulha da rotacao nao descolava e portanto é 1 VDO
basto desligar e voltar a ligar a ja ta
esperar que nao volte a acontecer muita vez
