caixa de 6 velocidades
Pessoal sabem-me dizer s seria possivel colocar no meu a3 110 uma caixa de 6 velocidades (do 130) ?
obrigado
fika a lista d material se te kiseres aventurar... :twisted:
:arrow:
6-Speed gearbox Conversion
Description, Quantity, and Part Numbers
Transmission 1 DRW -- WWO3 02m-301-107-D is the proper code for the GTI TDI 150 PD 6-speed gearbox
[n.b, the axle p/n are from the euro PD130/PD150 ASZ/ARL cars]
Left Drive Shaft 1 1J0 407 271 GC $756.77
Right Drive Shaft 1 1J0 407 272 GD $364.35
Driveshaft axle 12pt nuts 30mm 2 N 905 876 02 $5.50 ea.
N 105 316 01 Bolt, with multi spline socket head M10x23 $1.44 ea, need 12
Driveshaft Bolt Retainers 6 1J0 407 357 A $1 ea.
Transmission Mount 1 1J0 199 555 AQ $78
Transmission Brace 1 1J0 199 117 AK $32
N 102 096 03 hexagonal head bolt M12X1, 5X65 qty 2 trans mount TTY Single Use
N 102 683 02 hexagon head bolt c/w shoulder AM8X45 qty 2 dogbone to trans TTY Single Use
N 102 466 04 hexagon head bolt c/w shoulder M10X30-SW!6 qty 1 dogbone to body TTY Single Use
N 905 970 01 hexagon head bolt c/w shoulder M10X70-SW!6 qty 1 dogbone to body TTY Single Use
BOLT for trans to engine N10242102 $3.08
BOLT,HEX for trans to engine N90884601 $4.23
Reuse other bolts
Dust Cover 1 06A 103 645 $8.32
Inspection Cover 1 068 103 645 M $6.49
Bolt for inspection cover 1 N 010 208 5 $.50
Washer for Inspection Cover 1 N 012 226 5 $.20
Mounting Bolts 2 N 908 703 01 $1.54 ea.
Starter Bolts 2 N 907 665 02 $6.76 ea.
Starter 1 02M 911 023 $350
Flywheel 1 038 105 266 Q $599
Clutch Disc 1 06A 141 031 Q $208 2.8L VR6 24V Jetta
Pressure Plate 1 06A 141 025 K $177 2.8L VR6 24V Jetta
Pressure Plate Bolts 6 N 903 086 05 $0.29 ea.
Release Bearing - Hydraulic - 02M141671A (or B?) $132.45
Bleeder 1 1J0 721 468 B aka "BREATHER ASSY." $26.52
Slave Cylinder Hose aka "tube line" 1 1J1 721 465 AJ $114 common to vr6 6-speed
Hose Clip 1 1J0 721 491 $1.33
Shifter Boot/Knob 1 1J0 711 113___ (various) $60 to $250 (browse vwparts.com)
3 qts of Redline MTL gear oil $9 each
1J0 711 051 H GEARSHIFT LEVER FRONT 6-SPEED GEARBOX F 1J-1-640 001>>* $29.70
OR...? 1J0 711 051 C GEARSHIFT LEVER FOR GEARBOX CODE: DRW F >> 1J-1-640 000*
1J0 711 781 D Abutment / bracket for shifter cables $14.77
N 90815903 Locking Washer for cable ends (need 2) $0.29 each
N 90908301 Shouldered Hex Nut, Self Locking $1.45
1J0711067L Bushing $1.35 ea. (need 2)
1J0711202J Relay levr $22.27
1J0711280B Lock Washer $0.52
N 10106903 Hex Head Bolt (Combi) M8x32 $0.52
06A103171A Crankshaft oil seal $45.00
If your car is pre-2002 with ball-end shifter cables, add:
1J0 711 266 F SELECTOR CABLE 6-SPEED MAN.GEARBOX ($125)
1J0 711 265 L SHIFT CABLE 6-SPEED MAN.GEARBOX ($125)
(Os preços estão em dólares, obviamente.)
Pouca coisa, não é?? :lol:
abraço
Rui
Bem cada vez que estiveres em 5ª e não tiveres a 6ª para meter, pensa nas cervejas que vais beber à conta disso.
Poupas uma centenas (€€€€), o que quer dizer que dá para umas milhares (cervejas)
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
sergiorod disse:
Eu prefiro o que foi dito aqui :wink:
Antunning disse:
Se calhar com o dinheiro que gastas, das o teu a troca e compras um de 130 :)
Quando fores por ventura chipar o teu carrito ...pegas no guito e vais juntando pro modelo que tenha mais alguns cv...assim tb poupas guito.
