check uo via vag-com a a4 b6
boas pessoal a dias tive com o ricardo e ele fez-me um check up ao carro via vag e apareceram os seguintes erros
VCDS Version: Beta 812.4
Data version: 20090214
Sunday,01,February,2009,23:09:03:26365
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 5765 67
69 75 76 77
VIN: WAUZZZ8E53A107770 Mileage: 348670km/216653miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906019 JT
Component: 1,9l R4EDC 0000SG 1572
Coding: 00003
Shop #: WSC 63351
WAUZZZ8E53A107770 AUZ6Z0B0140301
1 Fault Found
17571 - Fuel Temp Sensor (G81): Open or Short to Plus
P1163 -35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614517 A
Component: ABS/ESPallrad 1726
Coding: 04255
Shop #: WSC06435
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820043 H
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC63351
1 Fault Found
01841 - Potentiometer/Actuator for Temperature Flap; Left(G220)
30-10 -Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907279 E
Component: int.Lastmodul RDW 0305
Coding: 00011
Shop #: WSC63351
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959655 B
Component: Airbag8.4EP 2000
Coding: 0010602
Shop #: WSC 63351000 00000
No Faults Found
or DTCs notsupported by controller
or a communicationerror occurred
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953549 F
Component:Lenksáulenmodul 0308
Coding: 00012
Shop #: WSC63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920900 K
Component:KOMBI+WEGFAHRS. RB4 D35
Coding: 01100
Shop #: WSC00047
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959433 AS
Component:Komfortgerát T01 1210
Coding: 07012
Shop #: WSC36200
Part No: 8E1959801B
Component:Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component:Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component:Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component:Tõrsteuer.HR BRM 0002
3 Faults Found
01331 - Door Control Module; Driver Side (J386)
80-00 -Single-Wire Operation
01561 - Left Rear Door
61-00 -Won't De-Safe
01562 - Right Rear Door
61-00 - Won't De-Safe
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907357
Component:dynamische LWR D07
Coding: 00060
Shop #: WSC63351
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035186
Component: concertII GRO 0008
Coding: 01001
Shop #: WSC63351
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919283 A
Component:Parkingsyst. A4 RDW D08
Coding: 00114
Shop #: WSC63351
sera q alguem me podia ajudar a decifrar alguns erros??
abraço
Primeiro antes de tudo, deverias apagar esses erros, andar 1 2 dias com a carrinha e voltar a fazer 1 Scan ao carro para ver quais erros voltam!
Entretanto ao erros que tem:
1 Fault Found
Possiveis Sintomas
  • Consumo de combustivel mais Alto do que o normal
  • Carro nao pega tao facilmente como normal
  • Emissoes de Gases incorrectos/fora de escala
Possiveis Causas
  • Fio/Connector para/de Sensor de temperatura do Combustivel (G81) Avariado/Estragado
  • Sensor Temperatura Combustivel (G81) Avariado
Possiveis Soluções
  • Reparar o fio ou o Conector ao Sensor de temperatura do motor (G81)
  • Trocar o Sensor de Temperatura de COmbustivel (G81)
1 Fault Found
Possiveis Sintomas
  • Flap de temperatura não mexe ou está em posição incorreta
Possíveis Causas
  • Flap de Temperatura não mexe
  • Fios com defeito/traçados
  • Potenciómetro/Atuador do Flap Esquerdo de temperatura (G221) Com defeito
Possiveis Soluções
  • Realizar um basic setting no Vag-Com
  • Chekar a temperatura do ar do Flap, Se necessario lubrificar o Flap
  • Verificar fios electricos
  • Substituir Potenciómetro/Atuador do flap de temperatura Esquerdo (G221)
3 Faults Found
Possible Symptoms
  • Data Bus Comfort working in Single-Wire Mode
Possible Causes
  • Wiring/Connectors from/to Door Control Module Driver Side (J386)
  • Control Module in CAN Data Bus Comfort faulty
Possible Solutions
  • Check Measuring Value Blocks (MVB)
  • Check Wiring/Connectors from/to Door Control Module Driver Side (J386)
Possible Causes
  • Wiring/Connector from/to Central Locking Actuator (Safe): Rear Left Door (F222) faulty
  • Central Locking Actuator (Safe): Rear Left Door (F222) faulty
Possible Solutions
  • Check Wiring/Connector from/to Central Locking Actuator (Safe): Rear Left Door (F222)
  • Check Central Locking Actuator (Safe): Rear Left Door (F222)
    • See Measuring Blocks OR perform Output Test
Possible Causes
Possible Solutions
Basicamente é isso nada de muito complicado! ;)
