CIRCULAR INTERNA
Circular Interna (verdadeira) de uma multinacional americana em Portugal (no Porto), contra a linguagem dos trabalhadores do Norte!!!!
It has been brought to our attention by several officials visiting our corporate Headquarters that offensive language is commonly used by our Portuguese-speaking staff..
Such behavior, in addition to violating our Policy, is highly unprofessional and offensive to both visitors and colleagues.
In order to avoid such situations please note that all Staff is kindly requested to IMMEDIATELY adhere to the following rules:
1) Words like merd@, c@r@lho, fod@-se, porra or put@-que-o-pariu and other such expressions will not be used for emphasis, no matter how heated the discussion.
2) You will not say c@g@d@ when someone makes a mistake, or ganda-merd@ if you see somebody either being reprimanded or making a
mistake, or que-grande-c@g@d@ when a major mistake has been made. All forms derivate from the verb c@gar are inappropriate in our environment.
3) No project manager, section head, or executive, under no circumstances, will be referred to as filho-da-put@, c@brão, ó-grande-come-merd@, or vaca-gorda-da-put@-que-a-pariu.
4) Lack of determination will not be referred to as falta-de-c@lhões or coisa-de-maricas and neither will persons who lack initiative as
pich@-mole, c@rno, or mariconso
5) Unusual or creative ideas from your superiors are not to be referred to as punhet@-mental.
6) Do not say esse-c@brão-enche-a-porra-do-juízo if a person is persistent. When a task is heavy to achieve remember that you must not say é uma-fod@. In a similar way, do not use esse-gajo-está-f@did@ if colleague is going through a difficult situation. Furthermore, you must not say que-puted@ when matters become complicated.
7) When asking someone to leave you alone, you must not20say vai-à-merd@. Do not ever substitute "May I help you" with que-porra-é-que-tu-queres?? When things get tough, an acceptable statement such as "we are going through a difficult time" should be used, rather than isto-está-tudo-f@dido.
8) No salary increase shall ever be referred to as aumento-dum-c@brão.
9) Last but not least after reading this memo please do not say mete-o-no-cu. Just keep it clean and dispose of it properly.
We hope you will keep these directions in mind.
Thank you.
Como é óbvio esta circular só existiu pk houve um grande-come-merd@ que foi xibar á p@t@ da administração o que c@ralh@ certas palavras significavam.. :green: :green:
