Faz um Scan com o Vag-Com
Friday,08,April,2011,19:34:58:36838
VCDS Version: Release 10.6.2
Data version: 20101123
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 62 72
VIN: WAUZZZ8PX8A122063 Mileage: 61050km/37934miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC 000SG 9828
Revision: --H07--- Serial number: AUX7Z0GDFN70NI
Coding: 0000072
Shop #: WSC 06325 000 00000
VCID: 6FE6CF3807E1
1 Fault Found:
001025 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
Mileage: 60973 km
Time Indication: 0
Date: 2011.04.07
Time: 20:39:06
Freeze Frame:
RPM: 1722 /min
Speed: 44.0 km/h
Load: 17.3 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 285.0 mg/str
Mass Air / Rev.: 660.0 mg/str
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73EEC3486BC9
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0430
Revision: 225346 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
VCID: 71E2C94011D5
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007987920
Coding: E9881F01901410004F1600001600000000195E171E0102AE000000000000
Shop #: WSC 06314 000 08192
VCID: 458A4D9075DD
Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557 B
Component: REGENLICHTSENSORH13 0100
Coding: 00478253
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP00217EL
Coding: 0071612
VCID: 4B9E7BA853B9
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
VCID: 78F4F46472AF
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 224DG003127716
Coding: 0004128
Shop #: WSC 00025 261 89618
VCID: 356A3D50253D
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07C05024F
Coding: E9807F061000022102
VCID: 30640C44DA5F
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H22003 Serial number: AUX7Z0GDFN70NI
VCID: 356A3D50253D
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000144
VCID: 438E53887BE9
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356A3D50253D
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 L
Component: KSG H11 0080
Coding: 1880202002587F0085054C4F0377
VCID: 458A4D9075DD
Component: Sounder No Answer
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674752890854
VCID: 356A3D50253D
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000144
VCID: 448C50947EE7
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 4182598061F5
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 4280568C64F3
