Fica assim
E0A = No special edition
0GZ = Emission standard EU3, diesel with EOBD
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
6XE = Exterior mirrors: electrically foldable and electrically adjustable/heated
5SL = Left exterior mirror: aspherical
5RU = Right exterior mirror: convex (large viewing field)
1KD = Disc brakes, rear
J1G = Battery 450 A (92 Ah)
1LA = Disc brakes, front
1BY = 4-corner air suspension for rough-road design
3FE = Electric slide/tilt sunroof with sun screen/sunblind
5TS = Decorative burr walnut inserts, natural, high-gloss
7X2 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
8GU = Alternator 140 A
0G1 = Gearshift lever
0YZ = Without determination of weight categoryfor rear axle
0JZ = Without determination of weight categoryfor front axle
T1K = 6-cylinder diesel engine 2.5 L unit 059.E
3NZ = Rear seat bench unsplit, backrest split folding
8JG = Headlight with gas discharge lamp for driving on the right
U1C = Instrument insert with km/h speedometer,clock, tachometer, trip odometer and add. instruments (volt., oil temperat.)
X3B = National sales program Spain (FBU)
1N1 = Power steering
2ZQ = Leather trimmed multi-function steering wheel for air bag system
3HA = Without leather parts scope
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q2 = Multi-function display/on-board computerwith check control
8Z6 = Hot country
MR1 = 6-cyl. diesel engine 2.5 L/132 kW 24V TDI with fuel distributor injection pumpbase engine is T1K/T5T
7Q2 = Navigation system with color screen
CL3 = Alloy wheels 7.5J x 18
7K1 = Tire pressure warning light
4X4 = Side air bag, front and rear with curtain air bag
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SE = Additional engine and transmission guard(depending on body)
Q1N = Reinforced standard seat, front
4GK = Laminated windshield, with sunshield
