Diagonóstico vag-com c/ erros em audi A4 B8 2008 (ajuda)
boas pessoal, eu tenho um vagcom, e comprei uma audi a4 b8 de 2008 com 77.000km, ha dois dias, decidi fazer um diagonostico com o meu vagcom e o resultado foi este que vou colocar, podiam dizer-me o significado deste diagonostico?
Saturday,01,December,2012,17:50:35:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72 77
VIN: WAUZZZ8K99A011557 Mileage: 77580km/48205miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 B HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3210
Revision: --H01---
Coding: 0104002C18072020
Shop #: WSC 00019 261 55061
ASAM Dataset: EV_ECM20TDI03L906022B A01014
ROD: EV_ECM20TDI03L906022B.rod
VCID: 2443E8A39E4B
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AQ HW: 8K0 907 379 AQ
Component: ESP8 front H03 0210
Revision: -------- Serial number: --------------
Coding: 160500
Shop #: WSC 06335 000 00000
VCID: 881B1C1382A3
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 M HW: 8K0 907 064 M
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 030200
VCID: 3A7F36DB0CCF
Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 N HW: 8T1 820 043 N
Component: KLIMA 1 ZONE H05 0120
Revision: A0000000 Serial number: 0115.04.080281
Coding: 34000000
VCID: 3C7330C306FB
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H21 0253
Revision: 04021001 Serial number: 00000000125924
Coding: 26005091403400000001000000001D0D001C070800010001000000
VCID: 2F69178FC78D
Part No SW: 8K1 955 119 HW: 8T1 955 119
Component: WWS 150408 H06 0060
Coding: 00FD11
Part No SW: 8K0 941 531 B HW: 8K0 941 531 B
Component: E1 - LDS H07 0070
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230810212366
Coding: 100003
VCID: 397D29D709C9
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD14TB02
Coding: 30343434363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7330C306FB
Driver's Airbag Crash Sensor:
Serial number: 6334MSME3A157067C
Passenger Side Airbag Crash Sensor:
Serial number: 6344MSME28506666D
Driver's Rear Airbag Crash Sensor:
Serial number: 6352QSME60641B47G
Passenger's Rear Airbag Crash Sensor:
Serial number: 6362QSME5C0F4F33Z
Driver's Front Airbag Crash Sensor:
Serial number: 63732SME5D38280B6
Passenger's Front Airbag Crash Sensor:
Serial number: 63832SME604F4B2FE
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HDN000CG
Coding: 000013
VCID: 3D753DC71DE1
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 C HW: 8K0 920 900 C
Component: KOMBIINSTR. H15 0221
Revision: 00000000 Serial number: 7VL199H48
Coding: 0F04100002000008060000
VCID: 2A5F069BFC6F
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G08328891E
Coding: 000303
VCID: 4687522B4837
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0150
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 144
Mileage: 77240 km
Time Indication: 0
Date: 2012.11.01
Time: 16:47:00
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000007058894
Coding: 011002204000410001
VCID: 408B44336A13
1 Fault Found:
02110 - Window Regulator Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 98
Reset counter: 142
Mileage: 72876 km
Time Indication: 0
Date: 2012.05.18
Time: 09:05:48
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0111045830
Coding: 0100062020390040012002
VCID: 3A7F36DB0CCF
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 29
Reset counter: 191
Mileage: 53957 km
Time Indication: 0
Date: 2012.08.17
Time: 12:37:40
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 73
Mileage: 53957 km
Time Indication: 0
Date: 2012.08.17
Time: 12:41:19
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 146
Mileage: 77546 km
Time Indication: 0
Date: 2012.11.30
Time: 19:22:06
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000007044339
VCID: 3F8947CF17ED
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 00000000113778
Shop #: WSC 00000 000 00000
VCID: 306B14F3DAB3
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 346318E32EAB
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 104
Mileage: 77237 km
Time Indication: 0
Date: 2012.08.24
Time: 09:54:26
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 B HW: 8T1 035 186 B
Component: Concert3 H13 0150
Revision: 00000516 Serial number: AUZ5Z6H1049595
Coding: 0500048204028500015B070000
VCID: 366722EB38D7
Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 144
Mileage: 77234 km
Time Indication: 0
Date: 2012.08.23
Time: 10:07:16
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000007052330
Coding: 010002204000210001
VCID: 408B44336A13
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000007053132
VCID: 3F8947CF17ED
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 B HW: 8T0 862 335 B
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005045656
Coding: 0010390
VCID: 397D29D709C9
nao ha luzes nenhumas de avarias, no quadrante esta tudo correcto.
A unica coisa que noto é o vidro do condutor nao tem a mesma resposta que os outros, as vezes tenho de clicar 2 ou 3x vezes para ele fechar
entao o melhor que tens a fazer em 1º lugar, é o que ja disse o nosso colega em cima, apaga todos os erros, e ve se voltam apos uns kilometros ;)
Devido a estes 2 erros:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 29
Reset counter: 191
Mileage: 53957 km
Time Indication: 0
Date: 2012.08.17
Time: 12:37:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 28
Reset counter: 73
Mileage: 53957 km
Time Indication: 0
Date: 2012.08.17
Time: 12:41:19
Verifica se a tua tampa de combustível fica trancada quando trancas o carro...deveria, mas suponho que não esteja a acontecer. Depois diz qualquer coisa!
Foi o motor da tampa de combustível à vida ... para um B8 acho que anda na casa dos 140€ na audi, colocado no sitio ...
Quase todos os B8 tiveram esse problema da tampa. O meu teve e foi substituida em garantia. disseram-me que todos no concessionario tinham levado um trinco novo.
A peça em questão custa cerca de 20€, depois é só fazer conta a mais algum da mão de obra, mas nunca chega a esse valor. É um problema comum em todos estes modelos recentes. Eu tb já tive de trocar a tal peça no meu Q5.
