Que me dizem disto?! ![Big Grin :green: :green:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
Initial Steps:
Plug the VAG-COM device into the vehicle
Turn ignition key to 'ON' (do not start engine)
Start up the VAG-COM software
Click on 'Autoscan'. This will take you to another screen.
Click on 'Gateway installation list'. This will scan your vehicle to determine what 'gateways' are available and whether they have any Diagnostic Trouble Codes. Any items listed in red after the scan have trouble codes. Make note of what the codes are for each red item, and return to the Gateway Installation List screen. If there are no red items (items with DTCs), then don't worry, just proceed on with your coding.
Click on 'Clear all DTCs' and follow the prompts.
Proceed on with desired item below....
Enable Digital Speedometer Function in Concert II Head Unit:
Follow 'Initial Steps', above, then...
Click on '56-Radio'
When you go into this module, it will scan for fault codes and go straight to a fault code screen. It should say 'No Fault Codes Found'. Click the 'Done, go back' button to get to the main screen for this module.
Click on 'Recode - 07'
Make note of your original coding.
Hover over the code with the mouse pointer, and it will show a pop-up balloon with information about the various digits of the code.
Most US models are coded 0001005. Add 400000 to the original coding. For example, this would change it to 0401005
Change this value in 'Software Coding _______'
Click 'Do It!'
Click 'Close Controller, Go Back'
To use this feature, turn off the radio, and hold 'Menu' while turning it back on. To get the normal display back, turn the radio off and back on. It's only in kilometres, not miles.
Initial Steps:
Click on '56-Radio'
Click 'Do It!'
