Erro no Vag-Com
  • Thread starter Thread starter Bruno Oliveira
B
Bruno Oliveira
Guest
malta, vejam os erros que me dao.
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Controller: 038 906 012 C
Component: 1,9l R4 EDC 0000SG 2803
Coding: 00002
Shop #: WSC 06435
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03304
Shop #: WSC 06435
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 M
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 900
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 00040
Shop #: WSC 00000
Ident.-Nr. Wegfahrs.:AUZ5Z0Y1172243
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 L
Component: ZV-Pumpe D14
Coding: 00032
Shop #: WSC 06435
1 Fault Found:
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
Address 56 -------------------------------------------------------
Controller: 4B0 035 152
Component: Radio 0001
Coding: 00201
Shop #: WSC 01059
End -------------------------------------------------------
e depois este que ja tinha apagado:
Control Module Part Number: 038 906 012 C
Component and/or Version: 1,9l R4 EDC 0000SG 2803
Software Coding: 00002
Work Shop Code: WSC 06435
1 Fault Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
Control Module Part Number: 8L0 920 900
Component and/or Version: KOMBI+WEGFAHRS. M73 D14
Software Coding: 00040
Work Shop Code: WSC 00000
Additional Info: Ident.-Nr. Wegfahrs.:AUZ5Z0Y1172243
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
opinem
PS: o carro a partir das 3mil, entra-me em safe.
esse erro do pressao do turbo, so vejo duas hipoteses:
ou a n75 nas couves
ou a geometria do turbo
Verifica todas as tubagens desde a N75 ao turbo e as de admissão desde o turbo até ao colector de admissão, poderá ser uma fuga qq.
Testa a geometria com o vag com (teste a N75).
Thunder disse:
obrigado, vou ver se tenho alguma fuga, ja agora, o teste a n75 e onde?
Entras no vag com, seleccionas o modulo do motor.
Depois aparece la uma função q diz "output Test", (julgo ser esta a designação) e testa os varios componentes.
Inclusive desliga o motor, mas nao te assustes, é normal do teste.
Thunder disse:
Vou testar.
obg
Thunder disse:
Boas
E ao fazer esse output test o que é suposto aparecer mesmo? eu ja tentei fazer, mas o motor apenas soluça um pouco e vai abaixo, nao aparece mais informação nenhuma, isso quer dizer que esta tudo ok?
Quando aparece no pc o teste a N75, vais ao turbo e ves manualmente (com cuidado por causa das elevadas temperaturas) se o actuador da geometria se move ou se ta preso(a peça onde liga o tubo de vácuo q vem da N75). Tb pode acontecer de se deslocar mas não ser o suficiente.
Tb podes apagar o erro e verificar mais tarde se volta a aparecer, pq tb pode ser uma avaria esporádica.
boas,
fiz o teste, e antes de chegar a n75, ele desliga o motor correcto?
carrego next vai para o teste da n75, e que faço a seguir?? é que o carro fica desligado.
PS: Ontem 04.02.2007 fui a serra da estrela, e senti o tipo assobio da geometria a abrir e a fechar. Vim a puxar pelo caminho e ja nao me entrava em safe. Acontece que hoje puxei de novo, e ja entrou, e deixei de ouvir a geometria abrir e a fechar... para mim é a geometria do turbo que fica presa.
diz-me coisas THUNDER
O nosso Camarada NUNO GOMES, tb teve um problema semelhante a esse.
Resolução:
Depois de ter feito um km em Autoestrada o problema passou....
E esta hein :!: :!: :!: :!:
boas
Quando fica a testar a n75, vais ao turbo e ves se há o movimento do actuador da geometria. Pelo q dizes parece-me ser é a geometria q prende de vex em quando devido tlavez a carvão acumulado, visto q so te falha de vez em quando.
Tb tive esse problema na minha a4 110, entrou em safe varias vezes durante um dia (e tal como dizes deixava de ouvir o assobio do turbo, desligava a ignição e voltava a arrancar e ja tava bom.). Cheguei a casa liguei-lhe os cabos e nenhum erro. Nos dias seguintes dei-lhe uns estiquões em estrada e nunca mais entrou em safe.Desconfio q teve esse problema tb.
Tal como disse o Luciano Rato acerca do caso, pode ser q um pouco de estrada a puxar mais um pouco resolva esse problema.
não me parece que um pouco de estrada resolva isto...
estou a ver que tenho e de tirar o turbo e dar-lhe uma limpadela... :(
Numa casa especialista em turbos devem dizer logo qual o problema, antes de desmontar qq coisa. Aqui pelo diagnostico q dizes e provavel q seja isso.
Um primo meu tem um a3 9o cv e acontecia-lhe isso montes de vezes. Foi a VianaTurbo e limparam o turbo e ficou bom. ficou julgo q em 200 euros a reparação, mas posso confirmar o valor com ele.
Thunder disse:
hum....
se for esse preço meto logo um VB :D
