boas estive a ver uma a4 b5 de 96 para comprar tem estes erros alguém me sabe dizer o que e.foi lido com as portas abertas
Wednesday,23,October,2013,20:31:27:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 337080km/209451miles
Part No: 028 906 021 CE
Component: 1.9l R4 EDC 00SG 0803
Coding: 00002
Shop #: WSC 06325
VCID: 54AD6289A4E06E9
2 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
00527 - Intake Manifold Temperature Sensor (G72)
30-10 - Open or Short to Plus - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111
Component: ABS 5.3 FRONT D11
Shop #: BB 24303
VCID: DBBF09B5493E211
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04163
Shop #: WSC 06325
VCID: 2953E37DD3E2031
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 B
Component: Airbag V AUDI D01
Coding: 00766
Shop #: WSC 06315
VCID: 32610411FE34409
Address 17: Instruments Labels: 8D0-919-0xx-17.lbl
Part No: 8D0 919 034
Component: B5-KOMBIINSTRUMENT D10
Coding: 00140
Shop #: WSC 00006
VCID: E6C92841827C6C9
Address 25: Immobilizer Labels: 4A0-953-234.lbl
Part No: 4A0 953 234 F
Component: IMMO AUZ9Z0T8951518 D77
Coding: 00000
Shop #: WSC 00000
VCID: 254BEF4DBFFA271
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 E
Component: ZV-Pumpe
Coding: 00032
Shop #: WSC 65535
VCID: 56A99881B21C7C9
3 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01363 - Switch for Central Locking; Driver's Door (F59)
27-00 - Implausible Signal
01389 - Tailgate Open Switch (F124)
29-00 - Short to Ground
Coding: 00002
Shop #: WSC 06325
2 Faults Found:
Readiness: N/A
Shop #: BB 24303
Coding: 04163
Shop #: WSC 06325
Coding: 00766
Shop #: WSC 06315
Coding: 00140
Shop #: WSC 00006
Coding: 00000
Shop #: WSC 00000
Component: ZV-Pumpe
Coding: 00032
Shop #: WSC 65535
3 Faults Found:
35-00 - -
