Bom dia!
Antes de mais nada quero felicitar-vos pelo excelente forum.
Sou um novato no Vag-com e neste fim-de-semana liguei um vag-com 908 ao meu audi a3 1.9tdi sportback de 2008 onde fiz um diagnostico e foram detectados os seguintes erros:
O mais estranho é que no quadrante não aparece luz nenhuma a indicar uma avaria!
Já consultei o site da Ross-Tech, mas tenho alguma dificuldade em enterpretar as informações.
Precisava de uma ajudinha.
VCDS Version: Release 908.0
Data version: 20090911
Saturday,09,October,2010,19:26:33:13314
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
VIN: WAUZZZ8P98A156872 Mileage: 52440km/32584miles
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Part No SW: 03G 906 021 RE HW: 03G 906 021 AB
Component: R4 1,9L EDC 000SG 1955
Revision: --H07--- Serial number: AUX7Z0H1FNL0RB
Coding: 0000071
Shop #: WSC 06325 000 00000
1 Fault Found:
005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
P161B - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 1
Mileage: 50841 km
Time Indication: 0
Date: 2010.09.01
Time: 18:19:52
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000100
Temperature: 24.3°C
Bin. Bits: 01010000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
Shop #: WSC 06314 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0430
Revision: 251666 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
1 Fault Found:
00796 - Fan for Interior Temp Sensor (V42)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 34
Reset counter: 239
Mileage: 46417 km
Time Indication: 0
Date: 2010.03.11
Time: 18:52:44
Freeze Frame:
Voltage: 12.50 V
Temperature: 25.0°C
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4220
Revision: 91H01422 Serial number: 003CP002WW1L
Coding: 0070612
1 Fault Found:
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 0 km
Time Indication: 0
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.lbl
Part No SW: 8P0 920 931 E HW: 8P0 920 931 E
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 2241H003148228
Coding: 0004128
Shop #: WSC 00073 261 52269
Address 56: Radio Labels: 8J0-035-1xx-56.lbl
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8885113
Coding: 0110211
Obrigado.
Coding: 0000071
1 Fault Found:
P161B - 000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Mileage: 50841 km
Time Indication: 0
Date: 2010.09.01
Time: 18:19:52
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00000100
Temperature: 24.3°C
Bin. Bits: 01010000
Revision: 00H11001
Coding: 0021121
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 34
Reset counter: 239
Mileage: 46417 km
Time Indication: 0
Date: 2010.03.11
Time: 18:52:44
Freeze Frame:
Voltage: 12.50 V
Temperature: 25.0°C
Coding: 0070612
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 85
Mileage: 0 km
Time Indication: 0
Coding: 0000012
Coding: 0004128
Coding: 0110211
Obrigado.
