Erros Vag Com A3 130
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A069589 Mileage: 200620km/124659miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 CK
Component: 1,9l R4 EDC 0000SG 1243
Coding: 00002
Shop #: WSC 06435
WAUZZZ8LZ1A069589 AUZ7Z0Y1739450
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 06435 000 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 L
Component: A3 KLIMAAUTOMAT 0101
Coding: 00043
Shop #: WSC 06435
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 00104
Shop #: WSC 06435
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 931 E
Component: AB-KOMBIINSTR. VDO D12
Coding: 02040
Shop #: WSC 42854
1 Fault Found
00849 - S-contact at Ignition/Starter Switch (D)
31-00 - Open or Short to Ground
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D16
Coding: 15179
Shop #: WSC 06435
1 Fault Found
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 37: Navigation Labels: Redir Fail!
Part No: 8L0 035 192 D
Component: RNS 4.1 H06 BNO 0011
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 56: Radio Labels: Redir Fail!
Component: Radio BNO 0001
Coding: 00117
Shop #: WSC 06435
1 Fault Found
36-00 - Open Circuit
Quais os problemas?
tens algum problema com o carro ?
senão limpa os erros todos, anda com o carro uma semana ou assim e volta a ler os erros, podem ter sido esporádicos
Vou fazer isso, mas o que me levou a ligar o cabo foi que o RNS-D deixou de desligar quando tiro a chave e ligar quando a ligo, agora ficou manual.
obrigado
