ERROS . VAG-COM [ Ajuda na interpretação ? ]
Viva,
Venho por este meio colocar os erros que me apareceram assim que fiz um scan este fds com o VAG-COM:
Podem-me ajudar a interpretar isto ?
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8P24A137764 Mileage: 118720km/73769miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000
Address 09: Cent. Elect. Labels: None
Component: Gateway H08 .01.
Revision: 00028000 Serial number: 00000000532238
Coding: E5885F209214100A000000000000000000
Shop #: WSC 00000 000 00000
1 Fault Found
02071 - Local Databus
004 - No Signal/Communication
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3D1862300
Coding: 0401021
Shop #: WSC 06435 000 00000
3 Faults Found
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 118727 km
Time Indication: 0
Date: 2010.02.17
Time: 20:57:26
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 91
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 91
Tinha o rádio ligado na altura, terá algo a ver com isso ?
Tenho módulo BT instalado da nokia.
