Erros VAG-COM [Ajuda Urgente]
Bem é o seguinte, comprei uma Audi A4 B5 e reparei que o pedal do travao estava tipo esponjoso, depois de o carro já estar parado se carregar ele afunda um pouco mais tipo esponja mesmo.
Fui dar uma volta e travando bruscamente reparei que o ABS não está a funcionar.
Liguei o carro ao VAG-COM e os erros que apareceram foram os seguintes.
Alguem me pode dar uma ajudinha nisto?
Sunday,20,November,2016,16:42:18:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Mileage: 266900km-165843mi Repair Order:
Chassis Type: 8D - Audi A4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 266900km/165843miles
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8D0 907 401 H
Component: 2.5l/4VT EDC G00SG D42
Coding: 02002
Shop #: WSC 06325
VCID: 29591B2FD30CF956E3D-49D8
2 Faults Found:
18259 - Powertrain Data Bus
P1851 - 35-10 - Missing Message from ABS Controller - Intermittent
00575 - Intake Manifold Pressure
11-10 - Control Limit Not Reached - Intermittent
Readiness: N/A
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04143
Shop #: WSC 06335
VCID: 29591B2FD30CF956E3D-2580
5 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to Plus - Intermittent
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels:
VCID: 55A167DFACF48DB6975-5000
Note: Excessive Comm Errors
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 880 M
Component: B5-KOMBIINSTR. VDO D10
Coding: 04060
Shop #: WSC 00000
VCID: 3C77D27B2C9E7CFE88B-5000
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0W0654758
IMMO-IDENTNR: AUZ7Z0W0654758
No fault code found.
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 K
Component: ZV-Pumpe, Funk D06
Coding: 12896
Shop #: WSC 06325
VCID: 3D71DF7F378475F6BF5-4E42
1 Fault Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Limpas os erros e depois das uma volta. Fazes novo scan e coloca aqui.
Já apaguei os erros e de seguida fiz o scan e apareceram novamente todos menos o do airbag.
Coding: 04143
Shop #: WSC 06335
5 Faults Found:
Coding: 04060
Shop #: WSC 00000
Coding: 12896
Shop #: WSC 06325
1 Fault Found:
35-00 - -
Tens basicamente portinhola do ar encravadas (avaria/falta de lubrificação ou manutenção), o sensor da temperatura exterior avariado e por ultimo pequenas fugas de ar no sistema da bomba do fecho central ou portas. Mãos a obra para não piorar a situação.
De ABS, nada a apontar, mas tens de verificar o ABS e tubagens de vácuo dos travões.
As portinholas que te referes são quais as que controlam o ar quente e frio ou as que separam o ar para os pés ou para o vidro?
E o sensor da temperatura exterior sabes-me dizer onde se localiza?
Do ABS já eu suspeitava que haveria fugas no circuito de vacuo porque ontem andei a ver e encontrei isto
queria arranjar um esquema de todo o sistema para poder substituir toda a tubagem de vacuo para não ter esses problemas.
Se alguém me poder facultar o esquema das tubagens agradecia, já agora o ABS não está a funcionar o poderá ter a ver com a fuga das tubagens, também tenho o reservatório de óleo dos travões partido e com uma abertura na parte superior, poderá ser disso.
PS. Já vem um reservatório novo a caminho.
