Erros Vag Com Audi A6 2.7Tdi Avant 2006
  • Thread starter Thread starter svps3
Boas pessoal.
Sou leigo nesta matéria do Vag com .
Fiz um scan a minha carrinha e deu me este erro no engine.
É alguma coisa de me preocupar?
Part No SW: 4F1 910 401 HW: 4F0 907 401 C
Component: 2.7L V6TDI G000SG 0040
Revision: --H03--- Serial number:
Coding: 0011322
Shop #: WSC 02334 785 00200
VCID: DAB10CB11504D89
6 Faults Found:
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 102687 km
Time Indication: 0
Date: 2012.07.28
Time: 22:47:49
Freeze Frame:
RPM: 882 /min
Torque: 93.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 23.3 %
Temperature: 18.9°C
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 102687 km
Time Indication: 0
Date: 2012.07.28
Time: 22:47:49
Freeze Frame:
RPM: 882 /min
Torque: 93.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 23.3 %
Temperature: 18.9°C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 102687 km
Time Indication: 0
Date: 2012.07.28
Time: 22:47:49
Freeze Frame:
RPM: 882 /min
Torque: 93.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 23.3 %
Temperature: 18.9°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 102687 km
Time Indication: 0
Date: 2012.07.28
Time: 22:47:49
Freeze Frame:
RPM: 882 /min
Torque: 93.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.60 V
Duty Cycle: 23.3 %
Temperature: 18.9°C
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 102830 km
Time Indication: 0
Date: 2012.08.07
Time: 10:30:36
Freeze Frame:
RPM: 1428 /min
Torque: 74.1 Nm
Speed: 22.4 km/h
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 30.4 %
Temperature: 18.9°C
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 109940 km
Time Indication: 0
Date: 2012.11.06
Time: 11:49:03
Freeze Frame:
RPM: 882 /min
Torque: 109.2 Nm
Speed: 2.2 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Duty Cycle: 23.7 %
Temperature: 15.3°C
Ok.
Amanha vou ate o trabalho e volto e depois a noite ligo novamente para ver se tem os mesmo erros.
Eu apaguei e depois liguei novamente e estavam os erros la na mesma.
Mas deve ser por nao andar com a carrinha certo?
obrigado
Nopes... Se é assim é mesmo porque tens algum problema na alimentação das velas!!! Pelo menos é o que me parece... Pois não acho que possam ter dado o berro as 6 velas!! Nas nossas temperaturas quase não precisamos das velas para meter o carro a trabalhar... Nunca tiveste problemas a meter a trabalhar em tempo frio?
P161C/005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
Possible Symptoms:
No Pre-Glow Period
Poor Cold Starting
Possible Causes:
Glow Plug Wiring faulty
Glow Plug faulty
Possible Solutions:
Check Glow Plug Wiring
Check Glow Plug
Boas fiz o scan e os erros estao la .
Nunca custou a pegar ela dorme sempre na rua e nao se queixa LOL.
O que podera ser?
Sera melhor trocar os cabos das velas?
Sera caro?
