Ora bem amigos, até me assustei com tantos erros que me apareceram no VAG-COM, espero que metade seja por eu ter usado mal o programa :/
Deixo-vos aqui a lista de erros que me apareceram. Eu começei hoje a usar o programa, espero que isto seja a informação certa.
Desde já peço desculpa pela extensa lista...
VCDS Version: Release 12.12.0
Data version: 20130910
Tuesday,06,October,2015,23:51:05:62939
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P85A145983 Mileage: 264170km/164147miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0E2FN90PA
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6CD7223B4F7E2C7E58B-8039
5 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 11000100
Temperature: 11.7°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 11000100
Temperature: 11.7°C
Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 11000100
Temperature: 11.7°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 840 /min
Torque: 36.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 11000100
Temperature: 11.7°C
Bin. Bits: 10110000
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 2037 /min
Torque: 0.0 Nm
Speed: 91.0 km/h
Load: 0.0 %
Duty Cycle: 96.8 %
Bin. Bits: 11000011
Mass Air / Rev.: 310.0 mg/str
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
VCID: 3A7BD46375AA42CE9A7-806F
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH14 0180
Revision: 166702 Serial number: 8P0820043H
VCID: 3169F34FA8DC81962BD-8064
3 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 98
Mileage: 263300 km
Time Indication: 0
Date: 2015.08.17
Time: 19:31:31
Freeze Frame:
ON
00483 - Control Module for Auxiliary Air Heater
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 127
Mileage: 264173 km
Time Indication: 0
Freeze Frame:
ON
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 138
Mileage: 263300 km
Time Indication: 0
Date: 2015.08.17
Time: 19:31:05
Freeze Frame:
Voltage: 8.00 V
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H37 0301
Revision: 00H37000 Serial number: 00000001636622
Coding: 01884F02B214100000160000160000000000FE075C
Shop #: WSC 06314 000 08192
VCID: 3D71DF7F648475F6BF5-8068
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
7 Faults Found:
00059 - Terminal 30 for Interior Lighting
012 - Electrical Fault in Circuit
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
00985 - Right Tail Light (M2)
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground - Intermittent
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
010 - Open or Short to Plus - Intermittent
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 00362002F1SE
Coding: 0034622
VCID: 428BAC831D7A0A0EC27-8017
Subsystem 1 - Serial number: 6332DRB401B4D314K
Subsystem 2 - Serial number: 6342DRB401B10CA6P
Subsystem 3 - Serial number: 63528RB4003C91B4K
Subsystem 4 - Serial number: 63628RB4003B33DAO
Subsystem 5 - Serial number: 63729RB40055BB6EZ
Subsystem 6 - Serial number: 63829RB40055BB6AW
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 263300 km
Time Indication: 0
Date: 2015.08.17
Time: 19:31:25
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
010 - Open or Short to Plus - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 264064 km
Time Indication: 0
Date: 2015.10.03
Time: 00:00:58
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 264064 km
Time Indication: 0
Date: 2015.10.03
Time: 00:00:58
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000012
VCID: 3561C75F5CB4ADB6775-8060
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D06 Serial number: 2242ED06007139
Coding: 0004443
Shop #: WSC 00205 067 57207
VCID: 3663C05341B2A6AE7EF-8063
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
Freeze Frame:
Fault Status: 00000011
Fault Priority: 7
Fault Frequency: 50
Reset counter: 127
Mileage: 262334 km
Time Indication: 0
Date: 2015.06.26
Time: 16:49:27
16346 - Control Module - ROM Error
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 82298 km
Time Indication: 0
Date: 2006.08.31
Time: 11:12:48
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 250010522808D5
Coding: 3D3F0B42072103
VCID: 285F1E2B9B06C05EFC3-807D
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D06 Serial number: AUX7Z0E2FN90PA
Shop #: WSC 00583 210 02210
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0040
Coding: 0000048
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.8 1502
Shop #: WSC 00000 000 00000
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D088505489FC63000
VCID: 3C77D27B7F9E7CFE88B-8069
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001228724
VCID: F1E9B34FE85C4196EBD-80A4
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000048
VCID: 3E73D87369826EEEA6F-806B
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3E2159648
Coding: 0001001
Shop #: WSC 06435 000 00000
VCID: 326BFC43ADDABA8E527-8067
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 263986 km
Time Indication: 0
Date: 2015.09.25
Time: 00:16:03
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG 010 0030
Coding: 0000144
Address 72: Door, Rear Right Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51EF3FB4E4E5760F5-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
Espero que me consigam ajudar
