VAG-COM Version: Release 607.3-UD
Saturday,24,October,2009,20:50:31
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN Number: WAUZZZ8E23A264575
Address 01: Engine
Part No: 038 906 019 JQ
Component: 1,9l R4 EDC G000SG 1570
Coding: 00002
Shop #: WSC 06435
WAUZZZ8E23A264575 AUZ6Z0B0364877
No fault code found.
Readiness: 0 0 X X X
Address 03: ABS Brakes
Part No: 8E0 614 517
Component: ABS/ESP front 1729
Coding: 04255
Shop #: WSC 01024
Address 08: Auto HVAC
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
41-10 - Blocked or No Voltage - Intermittent
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
30-10 - Open or Short to Plus - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
Address 09: Cent. Elect.
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00011
Shop #: WSC 00178
Address 15: Airbags
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 2000
Coding: 0010602
Shop #: WSC 00178
Address 16: Steering wheel
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0911
Coding: 01042
Shop #: WSC 01024
Address 17: Instruments
Part No: 8E0 920 930 R
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00000
Shop #: WSC 00178
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 37: Navigation
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
Address 46: Central Conv.
Part No: 8E0 959 433 AS
Component: Komfortgerát T85 1310
Coding: 07008
Shop #: WSC 06435
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 4.10
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 4.10
Address 56: Radio
Part No SW: 8E0 035 192 R HW: 8E0 035 192 R
Component: RNS-E HIGH EU H73 0650
Coding: 0301215
Shop #: WSC 21072
5 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.10.24
Time: 20:26:08
Freeze Frame:
Mileage: 655350 km
Count: 2410
Clock: 20:39
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Time Indication: 0
Date: 2009.10.24
Time: 20:26:18
Freeze Frame:
Mileage: 655350 km
Count: 2410
Clock: 20:25
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Time Indication: 0
Date: 2009.10.24
Time: 20:26:10
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Time Indication: 0
Date: 2009.10.24
Time: 20:26:10
00466 - Control Module for Steering Column Electronics (J527)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Time Indication: 0
Date: 2009.10.24
Time: 20:26:13
Address 77: Telephone
Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
Component: FSE_256x BT H34 0520
Coding: 0010702
Shop #: WSC 63351
2 Faults Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 6
Reset counter: 58
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
End -----------------------------
