Boas .
Aqui deixo e minha lista de erros alguem me sabe dizer se alguma coisa a volta dos switchs porque como ja disse n'um topico ela nao acusa posrtas abertas mas o alarme fonciona bem
Sunday,17,April,2011,08:59:47:60804
VCDS Version: Release 10.6.0
Data version: 20100630
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 194330km/120751miles
Part No: 038 906 018 FD
Component: 1,9l R4 EDC G000SG 2137
Coding: 00002
Shop #: WSC 06325
VCID: 5DBA1C82FD59
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB81B8EF05F
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D54
Coding: 00043
Shop #: WSC 06325
VCID: 2A50875EFC97
3 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
29-10 - Short to Ground - Intermittent
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 0001
Coding: 00106
Shop #: WSC 06325
VCID: 3D7ABC021D19
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 881 H
Component: B5-KOMBIINSTR. VDO D15
Coding: 05140
Shop #: WSC 00000
VCID: 3874AD16323B
Part No: IMMO
Component: IDENTNR: AUZ7Z0X1114642
IMMO-IDENTNR: AUZ7Z0X1114642
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 13131
Shop #: WSC 06325
VCID: EAD0C75EBC17
13 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
01389 - Tailgate Open Switch (F124)
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
00957 - Key 3
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 06325
VCID: E0C4A5764A2B
esta e a lista antes de limpar algums
