Log de uma A4 de 2013 - Ajuda erro
Boas companheiros, um amigo pediu para ver se uma carrinha que pretende comprar tinha algum problema e então liguei ao VAG-COM.
Gostaria de saber se me podem ajudar sobre o erro que dá.
Desde já obrigado por alguma ajuda possive.
Deu o seguinte:
Monday,30,May,2016,19:14:03:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ8K3DA179025 License Plate:
Chassis Type: 8K (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K3DA179025 Mileage: 173460km/107783miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCB) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JP HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2842
Revision: 45H25---
Coding: 12194012232401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JP 003005
ROD: EV_ECM20TDI01103L906018AC.rod
VCID: 8109E38F10FC51161BD-80D4
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CH HW: 8K0 907 379 CH
Component: ESP8 front H09 0100
Revision: -------- Serial number: --------------
Coding: 161D44
Shop #: WSC 06325 000 00000
VCID: 8109E38F18FC51161BD-80D4
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 175
Mileage: 173206 km
Time Indication: 0
Date: 2016.05.20
Time: 13:59:48
Freeze Frame:
Hex Value: 0x3600
Hex Value: 0x4006
Hex Value: 0x1221
Hex Value: 0x1BB2
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GC HW: 8K0 907 064 FC
Component: BCM2 2.0 H11 0621
Revision: 00002001
Coding: 03A24000000000000000
VCID: 77FD0D57C6389FA6A59-8022
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K1 820 043 AG HW: 8K1 820 043 AG
Component: KLIMA 1 ZONE H02 0122
Revision: A1000000 Serial number: 01011220120810
Coding: 342002E000
VCID: 6DD12F3FB46425764F5-8038
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 134
Mileage: 173200 km
Time Indication: 0
Date: 2016.05.17
Time: 11:47:45
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DD HW: 8K0 907 063 DD
Component: BCM1 1.0 H16 0103
Revision: 04016001 Serial number: 00000519530502
Coding: 29000030803400C00081000300001F1F001C060826080401000004000000020000000020000000
VCID: 74E73A5BD74EF4BE80B-8021
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 031212 H07 0080
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 AR HW: 8K0 941 531 AR
Component: E1 - LDS H03 0031
Subsystem 3 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
1 Fault Found:
01229 - A/C Humidity Sensor (G260)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 134
Mileage: 173200 km
Time Indication: 0
Date: 2016.05.17
Time: 11:47:20
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD96XYFJ
Coding: 30514435363030303030554A304C384B3053
Shop #: WSC 49083 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 489FBEABF346205E1C3-801D
Crash sensor for side airbag; driver side:
Serial number: 6334MSME74712E39K
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME75202F16C
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME29272E64N
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME0E270E66R
Crash sensor for front airbag; driver side:
Serial number: 63732SME0A281256X
Crash sensor for front airbag; passenger side:
Serial number: 63832SME3F29094ED
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20121205000299
Coding: 000017
VCID: 4FAD95B71E28F7665D9-801A
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 931 J HW: 8K0 920 931 J
Component: KOMBIINSTR. H35 0556
Revision: 00000000 Serial number: UVP7622DD
Coding: 1384100003010008000000
VCID: 3561C75F9CB4ADB6775-8060
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y12B2304D2
Coding: 80CF07FF00
VCID: 4A9B84A3E54AD24E0A7-801F
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000035802536
Coding: 011002204000410001
VCID: 50AF96CB0316E89E443-8005
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0011043708
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X.rod
VCID: 3467FA5B9FCEB4BE40B-8061
1 Fault Found:
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 182
Mileage: 173131 km
Date: 2016.02.12
Time: 11:18:20
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0188354363
Coding: 0100062020B900408120023680000000
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000046952061
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001219599
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 387FCE6B83A650DE6C3-806D
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 F HW: 4G1 035 053
Component: Radio U Basic H41 0122
Revision: AB001007 Serial number: 226L.0C7600491
Coding: 010003020100000001
VCID: 224B0C033D3A2A0EA27-8077
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 652 B HW: 8R1 035 652
Component: B-BN-EU H62 0176
Revision: -------- Serial number: 148LD0C7595278
Coding: 01010001000621ED01800B4E000000030001
VCID: 326BFC436DDABA8E527-8067
Subsystem 1 - Part No: 4G0 919 884 L
Component: EUR 2013 1503
Subsystem 2 - Part No SW: 8T0 919 604 A HW: 8T0 919 604 A
Component: DU6 Basic H43 0098
Subsystem 3 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000046182907
Coding: 010002204000210001
VCID: 4683B093F152362EEEF-8013
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000046030241
