LOG VaG-COM RNS-D
Alguem ajuda???Ou como resolver estes 2 erros? Obrigado
Control Module Part Number: 4B0 035 192 M
Component and/or Version: RNS 4.1 H06 BNO 0102
Software Coding:
Work Shop Code:
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
49-00 - No Communications
00867 - Shareware Version. To Decode all DTCs
03-00 - Please Register/Activate
o modulo tmc esta dado como activo na configuraçao do rns-d e nao esta ligado ou as ligaçoes para o quadrante nao estao bem feitas/ ligadas.
Cardoso disse:
Nao tenho info no quadrante, nem TMC no sabes quais os valores a rever?
Para desligar "virtualmente" o TMC:
16) “Turn off TMC message” (if no TMC is installed):
To turn off the TMC warning you need VAG.com to adjust the settings. If your installer has VAG-COM then he/she should be able to connect to your car and in Module 37 set adoption channel 6 to 0, this should do the trick.
