O carro continua a tremer ao relanti a frio, fumo branco ocasional e cheiro forte. A quente desaparecem os sintomas.
Já levou os novos injectores e novo kit de vedantes.
As cams e cambota foram afinadas, valor Torsion Value actual : 1.50 º
Entretanto fiz este log com o carro ao relanti e a quente para confirmar valores.
Parece-me que que: o valor de consumo instaneo está alto, os valores de voltagem estão anormais e os valores dos injectores parece que também não estão a 100%...
Se alguém me pudesse ajudar a interpretar isto, agradecia.
Friday,26,September,2014,13:53:19:62939
VCDS Version: 12.12.0.0
Address 01: Engine (03G 906 018 DH)
13:53:14 Group 015: Fuel Consumption
799 /min Engine Speed (G28)
45.3 Nm Engine Torque
0.36 l/h Fuel Consumption
0.0 Nm Torque Request (Driver)
Friday,26,September,2014,13:54:15:62939
VCDS -- Windows Based VAG/VAS Emulator
Data version: 20130910
13:54:10 Group 019
134.25 V Voltage
127.25 V Voltage
135.75 V Voltage
136.25 V Voltage
13:55:01 Group 013: Idle Stabilization (Injection Quantity Deviation)
0.08 mg/str Injection Quantity Deviation Cyl. 1
-0.64 mg/str Injection Quantity Deviation Cyl. 2
0.55 mg/str Injection Quantity Deviation Cyl. 3
0.00 mg/str Injection Quantity Deviation Cyl. 4
13:55:10 Group 013: Idle Stabilization (Injection Quantity Deviation)
-0.55 mg/str Injection Quantity Deviation Cyl. 2
0.52 mg/str Injection Quantity Deviation Cyl. 3
-0.05 mg/str Injection Quantity Deviation Cyl. 4
13:56:06 Group 029: Temperature and Oil Level Sensor (TOG)
81.0°C Oil Temperature
29.1 mm Oil Level
0 km Wear Index
0 km Soot Index
13:58:30 Group 004: Unit Injector
803 /min Engine Speed (G28)
4.8 °ATDC Injection Start (specified)
4.2°KW Injection Duration (specified)
1.49° Torsion Value
13:58:38 Group 005: Start Conditions (last Engine Start)
796 /min Engine Speed (G28)
0.0 Nm Starting Torque
255.0 Start Synchronisation
89.0°C Coolant Temperature (G62)
13:59:38 Group 015: Fuel Consumption
806 /min Engine Speed (G28)
46.4 Nm Engine Torque
0.74 l/h Fuel Consumption
13:54:10 Group 019
134.25 V Voltage
127.25 V Voltage
135.75 V Voltage
136.25 V Voltage
29.1 mm Oil Level
0 km Wear Index
0 km Soot Index
1.49° Torsion Value
