Logs, Vag-Com
Boas pessoal!
Tentei fazer uns logs e deu isto. Agradeço se alguem me der umas dicas do que aqui tenho.
Peço desculpa mas não consigo inserir como tabela do DieselPower Log View.
Monday,27,February,2012,15:33:42:10074,VCDS Version: Release 10.6.0,Data version: 20100630
038 906 019 FP,,1.9l R4 EDC 0000SG 1467,
,Group A:,'001,,,,Group B:,'027,,,,Group C:,'010
,,Engine speed,Injected quantity,Spec. Inj. duration,Coolant temp,,RPM,Speed, ,Speed,,MAF,Atmos. pressure,Intake air press.,Throttle
,TIME,790-870,3.0-9.0,3-8 °Ck.,80-110°C,TIME,,,,,TIME,900-1250,sensor -f96-,2100-2600,100%
Marker,STAMP, /min, mg/str,°KW,°C,STAMP, /min, km/h,, km/h,STAMP, mg/str, mbar,, %
,0.01,3024,22.0,8.7,90.9,0.38,3066,73.0, ,0.0,0.78,1151.5,1009.8,2176.2,100.0
,1.18,3255,50.0,23.5,90.9,1.58,3339,79.0, ,0.0,1.98,886.9,1009.8,2117.7,100.0
,2.37,3528,49.1,24.5,90.0,2.73,3612,86.0, ,0.0,3.10,960.4,1009.8,2187.9,100.0
,3.46,3738,38.2,20.9,90.0,3.81,3696,91.0, ,0.0,4.17,465.5,1009.8,1333.8,27.5
,4.53,3675,17.6,7.7,90.0,4.89,3738,90.0, ,0.0,5.25,940.8,1009.8,1848.6,100.0
,5.61,3864,47.5,24.5,90.0,5.97,3948,94.0, ,0.0,6.34,872.2,1009.8,2141.1,91.8
,6.70,4074,46.1,24.5,90.0,7.08,3990,98.0, ,0.0,7.45,592.9,1009.8,1532.7,0.0
,7.84,3822,0.0,-3.1,90.0,8.24,3675,92.0, ,0.0,8.64,617.4,1009.8,1649.7,0.0
,9.04,3360,0.0,-2.0,89.1,9.44,3255,82.0, ,0.0,9.84,612.5,1009.8,1567.8,0.0
,10.24,2961,0.0,-1.0,89.1,10.64,2856,72.0, ,0.0,11.04,588.0,1009.8,1474.2,0.0
,11.44,2709,0.0,-1.0,88.2,11.84,2667,66.0, ,0.0,12.24,588.0,1009.8,1439.1,0.0
,12.59,2604,0.0,-1.5,88.2,12.95,2562,63.0, ,0.0,13.32,578.2,1009.8,1427.4,0.0
,13.73,2478,0.0,-2.0,88.2,14.12,2457,60.0, ,0.0,14.49,416.5,1009.8,1392.3,3.5
,14.88,2394,4.7,3.6,89.1,15.23,2394,58.0, ,0.0,15.59,303.8,1009.8,1275.3,33.3
,15.95,2394,21.7,9.7,89.1,16.31,2436,58.0, ,0.0,16.67,1004.5,1009.8,2012.4,54.5
,17.03,2562,34.3,14.8,89.1,17.39,2625,62.0, ,0.0,17.75,813.4,1009.8,1825.2,52.9
,18.11,2751,29.6,12.8,89.1,18.47,2814,66.0, ,0.0,18.83,984.9,1009.8,1942.2,65.9
,19.19,2961,38.7,17.3,89.1,19.55,3066,72.0, ,0.0,19.92,1073.1,1009.8,2363.4,100.0
,20.31,3255,50.0,24.0,90.0,20.72,3360,79.0, ,0.0,21.10,931.0,1009.8,2070.9,100.0
,21.50,3549,48.9,24.5,90.0,21.90,3633,86.0, ,0.0,22.30,960.4,1009.8,2258.1,100.0
,22.70,3801,47.8,24.5,90.0,23.10,3885,92.0, ,0.0,23.50,975.1,1009.8,2340.0,84.3
,23.90,3927,0.0,-1.0,90.0,24.30,3465,96.0, ,0.0,24.70,1215.2,1009.8,2620.8,100.0
,25.10,2751,51.9,21.4,90.0,25.50,2772,100.0, ,0.0,25.90,940.8,1009.8,2024.1,100.0
,26.30,2856,51.6,21.9,90.0,26.70,2898,105.0, ,0.0,27.07,984.9,1009.8,2176.2,100.0
,27.43,2961,51.3,22.9,90.0,27.79,3003,109.0, ,0.0,28.15,989.8,1009.8,2246.4,100.0
,28.52,3066,51.1,22.9,90.0,28.89,3087,112.0, ,0.0,29.30,1029.0,1009.8,2304.9,100.0
,29.70,3171,50.5,23.5,90.0,30.10,3192,116.0, ,0.0,30.50,1019.2,1009.8,2351.7,100.0
,30.90,3255,50.0,24.0,90.9,31.30,3297,120.0, ,0.0,31.68,1019.2,1009.8,2351.7,96.5
,32.03,3339,49.7,24.0,90.9,32.40,3381,123.0, ,0.0,32.78,529.2,1009.8,1848.6,0.0
,33.17,3276,0.0,-2.0,91.8,33.58,3171,119.0, ,0.0,33.98,455.7,1009.8,1170.0,0.0
,34.36,2982,0.0,-1.0,91.8,34.76,2961,110.0, ,0.0,35.16,436.1,1009.8,1134.9,0.0
,35.56,2898,0.0,-1.0,91.8,35.96,2877,106.0, ,0.0,36.36,445.9,1009.8,1123.2,0.0
,36.76,2814,0.0,-1.0,91.8,37.15,2793,103.0, ,0.0,37.56,617.4,1009.8,1228.5,67.5
Monday,27,February,2012,15:52:29:10074,VCDS Version: Release 10.6.0,Data version: 20100630
,Group A:,'001,,,,Group B:,'027,,,,Group C:,'011
,,Engine speed,Injected quantity,Spec. Inj. duration,Coolant temp,,RPM,Speed, ,Speed,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP
,TIME,790-870,3.0-9.0,3-8 °Ck.,80-110°C,TIME,,,,,TIME,2850-3150,2200-2400,2100-2600,35-80%
Marker,STAMP, /min, mg/str,°KW,°C,STAMP, /min, km/h,, km/h,STAMP, /min, mbar,, %
,0.01,1344,12.9,7.1,93.6,0.40,1806,0.0, ,0.0,0.80,1890,1438.2,1181.7,31.5
,1.20,1554,16.2,9.2,93.6,1.60,1386,8.0, ,0.0,2.00,1701,2060.4,1251.9,23.1
,2.40,2121,36.8,14.8,93.6,2.80,2667,17.0, ,0.0,3.17,2625,1020.0,1848.6,45.4
,3.58,2205,26.1,10.2,93.6,3.97,1869,26.0, ,0.0,4.37,2121,2295.0,1485.9,31.5
,4.78,2310,45.8,18.4,93.6,5.17,2583,35.0, ,0.0,5.57,2898,2346.0,2316.6,64.5
,5.95,3150,50.5,23.5,93.6,6.34,3402,47.0, ,0.0,6.74,3633,2346.0,2000.7,53.4
,7.13,3150,0.0,-1.0,93.6,7.52,2415,55.0, ,0.0,7.89,2394,2254.2,1977.3,50.2
,8.25,2478,43.9,17.9,92.7,8.60,2562,60.0, ,0.0,8.96,2667,2346.0,2550.6,73.7
,9.34,2772,51.9,21.9,92.7,9.71,2877,67.0, ,0.0,10.07,2982,2346.0,2375.1,72.9
,10.43,3087,51.1,23.5,92.7,10.80,3171,75.0, ,0.0,11.19,3276,2346.0,2328.3,73.3
,11.60,3360,49.4,24.5,92.7,12.00,3465,82.0, ,0.0,12.39,3549,2346.0,2351.7,75.3
,12.79,3654,48.6,24.5,92.7,13.16,3591,88.0, ,0.0,13.55,2898,1050.6,1719.9,48.6
,13.94,2457,51.9,19.9,92.7,14.33,2520,91.0, ,0.0,14.73,2562,2346.0,2538.9,69.3
,15.13,2583,49.4,20.4,92.7,15.53,2604,95.0, ,0.0,15.93,2604,1264.8,1474.2,61.0
,16.33,2604,5.2,2.6,92.7,16.73,2583,95.0, ,0.0,17.13,2583,1203.6,1170.0,45.4
,17.50,2562,3.0,2.0,92.7,17.86,2541,94.0, ,0.0,18.22,2520,1101.6,1088.1,43.8
,18.60,2520,2.7,2.0,92.7,19.01,2520,92.0, ,0.0,19.41,2499,1183.2,1076.4,43.8
,19.81,2478,5.8,3.6,92.7,20.21,2478,91.0, ,0.0,20.62,2457,1183.2,1064.7,43.4
,21.01,2457,8.2,4.1,92.7,21.41,2436,90.0, ,0.0,21.81,2436,1224.0,1064.7,44.2
,22.22,2436,8.8,4.6,92.7,22.61,2415,89.0, ,0.0,22.99,2415,1254.6,1076.4,44.2
,23.34,2415,15.4,7.1,92.7,23.71,2415,88.0, ,0.0,24.07,2415,1550.4,1146.6,34.7
,24.42,2436,24.2,10.2,92.7,24.79,2436,89.0, ,0.0,25.14,2436,1591.2,1544.4,48.2
,25.50,2457,25.5,11.2,92.7,25.86,2478,90.0, ,0.0,26.22,2478,1713.6,1591.2,43.0
,26.58,2478,28.8,12.8,92.7,26.95,2520,91.0, ,0.0,27.35,2520,1683.0,1649.7,49.0
,27.75,2541,28.0,12.2,92.7,28.16,2541,93.0, ,0.0,28.55,2541,1438.2,1579.5,51.0
,31.35,2520,3.3,2.0,92.7,30.56,2520,93.0, ,0.0,30.95,2520,1101.6,1123.2,43.8
,32.55,2541,36.5,15.3,92.7,31.75,2499,92.0, ,0.0,32.16,2499,2346.0,1099.8,35.5
,33.64,2625,51.9,21.4,92.7,32.92,2562,93.0, ,0.0,33.28,2604,2346.0,2199.6,58.6
,34.81,2751,51.9,21.9,92.7,34.02,2667,97.0, ,0.0,34.41,2709,2346.0,2094.3,50.6
,36.01,2877,51.6,22.4,92.7,35.21,2793,101.0, ,0.0,35.61,2835,2346.0,2164.5,50.6
,37.20,3003,51.3,22.9,92.7,36.41,2919,106.0, ,0.0,36.81,2961,2346.0,2246.4,51.0
,38.32,3108,50.8,23.5,92.7,37.61,3045,110.0, ,0.0,37.96,3087,2346.0,2304.9,49.4
,39.40,3213,50.2,23.5,92.7,38.68,3150,114.0, ,0.0,39.04,3171,2346.0,2351.7,49.8
,40.48,3297,49.7,24.0,92.7,39.76,3234,118.0, ,0.0,40.12,3276,2346.0,2351.7,51.0
,41.56,3360,49.4,24.5,92.7,40.84,3318,121.0, ,0.0,41.20,3339,2346.0,2351.7,51.4
,42.74,3276,0.0,-2.0,92.7,41.95,3402,124.0, ,0.0,42.35,3402,1050.6,1731.6,50.6
,43.91,2961,0.0,-1.0,92.7,43.13,3171,120.0, ,0.0,43.53,3087,1040.4,1158.3,49.8
,45.09,2583,0.0,-1.5,92.7,44.31,2856,108.0, ,0.0,44.69,2730,1020.0,1123.2,46.6
,46.29,2205,0.0,-1.5,92.7,45.49,2457,95.0, ,0.0,45.89,2331,1009.8,1111.5,42.2
,47.46,1911,0.0,1.0,92.7,46.69,2100,81.0, ,0.0,47.09,1995,999.6,1088.1,38.3
,48.54,1806,0.0,1.5,92.7,47.82,1848,70.0, ,0.0,48.18,1806,999.6,1076.4,36.3
,49.67,1764,0.0,1.5,92.7,48.90,1785,66.0, ,0.0,49.27,1785,999.6,1064.7,35.5
,50.87,1701,0.0,2.0,92.7,50.07,1764,65.0, ,0.0,50.47,1722,999.6,1064.7,35.1
,52.07,1575,0.0,2.6,92.7,51.27,1659,62.0, ,0.0,51.67,1617,999.6,1064.7,33.9
,53.20,1491,12.4,7.1,92.7,52.47,1533,58.0, ,0.0,52.84,1533,1152.6,1064.7,32.7
,54.28,1428,18.1,8.7,92.7,53.56,1470,54.0, ,0.0,53.92,1449,1234.2,1111.5,24.3
,87.99,1827,6.6,6.1,92.7,88.39,1848,44.0, ,0.0,87.63,1806,1122.0,1076.4,35.9
,92.52,1932,0.0,1.0,92.7,92.88,1932,47.0, ,0.0,93.24,1932,1050.6,1088.1,37.9
,93.59,1932,2.2,4.1,92.7,93.95,1932,47.0, ,0.0,94.32,1932,1060.8,1053.0,37.5
1,94.68,1932,5.2,5.1,92.7,95.04,1932,47.0, ,0.0,95.40,1932,1132.2,1041.3,37.9
,95.80,1932,5.2,5.6,91.8,96.20,1890,47.0, ,0.0,96.60,1911,1030.2,1029.6,37.5
,97.00,1890,0.0,1.0,91.8,97.40,1869,46.0, ,0.0,97.80,1848,1030.2,1041.3,36.7
,98.20,1827,3.3,4.6,91.8,98.60,1806,44.0, ,0.0,99.00,1806,1111.8,1053.0,35.9
,99.40,1785,4.9,5.1,91.8,99.80,1764,43.0, ,0.0,100.20,1764,1071.0,1029.6,35.5
,100.60,1722,2.2,4.6,91.8,101.00,1722,42.0, ,0.0,101.40,1701,1060.8,1029.6,34.7
Monday,27,February,2012,15:54:52:10074,VCDS Version: Release 10.6.0,Data version: 20100630
,0.39,3276,50.0,24.0,92.7,0.78,3381,49.0, ,0.0,0.01,3003,2346.0,2129.4,57.8
,1.56,2247,41.2,15.3,92.7,1.96,2310,54.0, ,0.0,1.17,2898,1132.2,1521.0,49.8
,2.76,2541,51.9,20.4,91.8,3.16,2646,61.0, ,0.0,2.36,2415,2335.8,1836.9,40.6
,3.89,2856,50.8,21.9,91.8,4.25,2940,69.0, ,0.0,3.54,2751,2346.0,2293.2,57.8
,5.00,3150,50.5,23.5,91.8,5.36,3234,76.0, ,0.0,4.62,3045,2346.0,2129.4,51.4
,6.07,3402,49.4,24.5,91.8,6.43,3486,82.0, ,0.0,5.72,3318,2346.0,2246.4,53.0
,7.16,3654,48.3,25.0,91.8,7.54,3717,88.0, ,0.0,6.79,3570,2346.0,2304.9,52.2
,8.34,3885,47.5,25.0,91.8,8.74,3969,94.0, ,0.0,7.94,3801,2335.8,2363.4,54.6
,9.52,4095,45.8,25.0,91.8,9.92,4179,100.0, ,0.0,9.14,4032,2305.2,2328.3,57.0
,10.73,4326,42.8,23.5,90.9,11.13,4389,105.0, ,0.0,10.33,4263,2254.2,2574.0,74.9
,11.92,3696,4.4,-1.0,90.9,12.32,3003,109.0, ,0.0,11.53,4452,2162.4,2304.9,77.7
,13.07,3066,51.1,23.5,90.0,13.43,3108,113.0, ,0.0,12.72,3045,2346.0,2644.2,78.5
,14.17,3171,50.2,23.5,89.1,14.53,3213,116.0, ,0.0,13.81,3150,2346.0,2024.1,52.6
,15.30,3276,49.7,24.0,89.1,15.70,3318,120.0, ,0.0,14.90,3255,2346.0,2199.6,55.4
,16.48,3381,49.4,24.5,89.1,16.88,3402,124.0, ,0.0,16.10,3360,2346.0,2258.1,54.2
,17.62,3465,49.1,24.5,89.1,17.97,3507,127.0, ,0.0,17.26,3444,2346.0,2328.3,53.0
,18.69,3549,48.9,25.0,89.1,19.05,3570,130.0, ,0.0,18.34,3528,2346.0,2351.7,53.8
,19.78,3612,48.6,25.0,90.0,20.14,3633,132.0, ,0.0,19.41,3591,2346.0,2363.4,54.2
,20.89,3675,48.3,25.0,90.0,21.28,3696,135.0, ,0.0,20.50,3654,2346.0,2363.4,55.0
,22.06,3738,48.0,24.5,90.9,22.46,3759,137.0, ,0.0,21.66,3717,2346.0,2538.9,62.6
,23.26,3801,47.8,25.0,90.9,23.66,3843,140.0, ,0.0,22.86,3780,2346.0,2538.9,74.1
,24.46,3885,47.5,25.0,90.9,24.84,3906,142.0, ,0.0,24.06,3864,2335.8,2421.9,76.9
,25.64,3948,47.2,25.0,91.8,26.04,3969,145.0, ,0.0,25.24,3927,2325.6,2340.0,77.3
,26.84,4011,46.9,25.0,91.8,27.24,4053,147.0, ,0.0,26.44,3990,2315.4,2316.6,77.7
Agradeço a quem puder ajudar. Obrigado.
