Erros no VAG COM:
Sunday,10,February,2013,12:59:56:37412
VCDS Version: Beta 11.3.0
Data version: 20110801
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A004906 Mileage: 236900km/147202miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 CK
Component: 1,9l R4 EDC 0000SG 1243
Coding: 00002
Shop #: WSC 06435
VCID: 62C1DB2CC16B
WAUZZZ8LZ1A004906 AUZ7Z0Y1535007
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 18945
Shop #: WSC 06435
VCID: E7D74A38AA49
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0101
Coding: 00043
Shop #: WSC 06435
VCID: 30656164DF07
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 K
Component: Airbag Front+Kopf 3008
Coding: 00304
Shop #: WSC 06435
VCID: 468927BC4D83
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 931 E
Component: AB-KOMBIINSTR. VDO D12
Coding: 00040
Shop #: WSC 25445
VCID: 31636460D40D
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
VCID: 2C5D7514F32F
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00013
Shop #: WSC 06435
VCID: E5CB40305045
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8L0 035 195
Component: Radio D00
Coding: 00010
Shop #: WSC 06435
VCID: EBDF3608B6A1
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
