Boa tarde
Após alguma pesquisa na net e algumas dicas de um "expert" em programação VAG aqui no Porto, encontrei um módulo compativel com o meu (8E0959433AD), e uma listagem de todos os modulos conforto da B6 e suas funcionalidades...aqui fica a listagem e o link...pode ser que ajude mais alguém...
The list of modules for B6:
Central locking (Version I * - the end of June 2002, to VIN 8E * 3 * 100000)
8E0 959 433 J - 433MHz, lighting package over the legs, crank
8E0 959 433 K - 433 MHz, power windows at the back (or crank).
8E0 959 433 L - 433MHz, leg space lighting package, rear power windows
8E0 959 433 N
8E0 959 433 Q
8E0 959 433 R
8E0 959 433 S
8E0 959 433 T
8E0 959 433 AA
8E0 959 433 AB - factory alarm, 433MHz, rear power windows
8E0 959 433 AC - factory alarm, 433MHz, rear power windows
8E0 959 433 AD - 433 MHz, power windows at the back (or crank).
8E0 959 433 AE - 433MHz, rear power windows
8E0 959 433 AF - 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 AG
8E0 959 433 AH - factory alarm, 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 AJ - factory alarm, 433MHz, leg space lighting package, rear power windows (or crank).
8E0 959 433 AK - factory alarm, 433MHz, leg space lighting package, rear power windows
8E0 959 433 AL - factory alarm, 433MHz, crank
8E0 959 433 AM - 433 MHz, packet feet of space lighting, crank
8E0 959 433 AN
8E0 959 433 AP - 433MHz, rear power windows
8E0 959 433 AQ - 433MHz, crank
Central locking system (version II * - from July 2002, the VIN 8E * 3 * 100001)
8E0 959 433 AR - 433 MHz, power windows at the back (or crank).
8E0 959 433 AS - 433 MHz, power windows in the rear.
8E0 959 433 AT - 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 BA - 433MHz, leg space lighting package, rear power windows (or crank).
8E0 959 433 BB - factory alarm, 315MHz, leg space lighting package, power windows in the rear.
8E0 959 433 BC - factory alarm, 433MHz, leg space lighting package, power windows in the rear.
8E0 959 433 BD - factory alarm, 433MHz, leg space lighting package, rear power windows (or crank).
* - In B6 are two different models of the central locking system - are not compatible. Looking for a replacement unit should be guided by this division (of comfort with the purchase of another version, such as AQ and the unit had bought BA - will result in the inability to assign a key to a PBX).
Module 8E0 959 433 | Ranno Randmaa
