Boas
Acabei fazer mais um auto scan ao meu A4 Avant 2.0TDI 140cv de 2005 com 160.000kms
Gostaria que me ajudassem a decifrar principalmente este erro do motor.
Friday,28,May,2010,20:46:21:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E55A459797
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC 0000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 71528 136 80668
1 Fault Found:
16685 - Cylinder 1: Misfire Detected
P0301 - 000 - - - Intermittent
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Inj. Quantity: 2.96 mg/str
Temperature: 72.0°C
(no units): 0.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10121
Shop #: WSC 06325
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001MG7Y
Coding: 0033622
1 Fault Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01012
Shop #: WSC 06325
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Coding: 0006041
Shop #: WSC 73249 020 01196
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BG
Component: Komfortgerát T85 2431
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000005
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01031
Shop #: WSC 34894
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 D HW: 8P0 862 335 D
Component: FSE_255x BT H18 0050
Coding: 0000511
Shop #: WSC 34894 142 82618
Cumprimentos e obrigado
69 75 76 77
Coding: 0000072
1 Fault Found:
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Temperature: 72.0°C
(no units): 0.0
Coding: 0004401
Coding: 00000
Shop #: WSC 00000
Coding: 10121
Shop #: WSC 06325
Coding: 0033622
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
Coding: 01012
Shop #: WSC 06325
Coding: 0006041
No Faults Found
Coding: 07024
Shop #: WSC 06325
Part No: 8E1959801B
Part No: 8E1959802B
Coding: 0000005
Coding: 01031
Shop #: WSC 34894
Coding: 0000511
