Digam lá qualquer coisa. O erro 17664 - Engine Coolant Temp Sensor (G62) já sei o que é, tenho que trocar o sensor.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Controller: 038 906 019 AN
Component: 1,9l R4 EDC 0000SG 1301
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 931 T
Component: B5-KOMBIINSTR. VDO D12
Coding: 00040
Shop #: WSC 00006
XXXXXXXXXXXXXXXXX AUZ7Z0Y1601179
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14945
Shop #: WSC 06435
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
End --------------------------
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
P1256 - 35-00 - -
Readiness: N/A
Coding: 00012
Shop #: WSC 06435
Coding: 00040
Shop #: WSC 00006
No Faults Found
Coding: 14945
Shop #: WSC 06435
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
35-00 - -
