Porta pendura nao destranca
boas malta.
já algum tempo para cá que tenho notado que a porta do pendura não destranca ao desligar o carro nem acende a luz interior quando abro por dentro.
liguei o vag e apareceu isto:
01366 - Opened Due to Crash Signal
35-00 - -
01560 - Passenger Door
61-00 - Won't De-Safe
já verifiquei se havia algum fio partido na dobra da porta, só tinha 1 traçado mas isolei.
será problema na fechadura?
colunas de áudio e vidro trabalham na perfeição.
cump
boas malta.
35-00 - -
cump
Tens este erro:
Possible Causes
Output Test performed on Airbag Control Module (J234) or Control Module for Central Locking (J429)
Vehicle involved in Accident
Airbag Control Module (J234) stored Crash Data
Wiring/Connectors from/to Airbag Control Module (J234) faulty
Possible Solutions
Check/Clear Fault Codes
Check Wiring/Connectors from/to Airbag Control Module (J234)
Já apagaste isso a ver se desaparece?
Quanto ao da porta:
01560 - Passenger Door: Won't De-Safe
Possible Causes
Wiring/Connector from/to Central Locking Actuator (Safe): Passenger Door (F221) faulty
Possible Solutions
Check Wiring/Connector from/to Central Locking Actuator (Safe): Passenger Door (F221)
Check Central Locking Actuator (Safe): Passenger Door (F221)
See Measuring Blocks OR perform Output Test
Special Notes
Safe states can normally only be checked while the car is being locked with ignition off, however usually the comfort system/central locking allows you to diagnose problems even with ignition off, as long as the diagnostic communication has been initiated before the ignition is being switched off. In detail this means switch on the ignition, connect to the comfort system/central locking and open the desired measuring block. Keep the measuring block running, switch off the ignition and lock the car. Finally when unlocking check if the actuator status changes as expected.
Se já isolaste o fio, apaga os erros e vê se já tens resposta do controlador!
batestes com o carro? é que o 1° erro indica isso...
No modulo do Airbag ñ tens erro nenhum? Luz do Airbag está apagada?
Bati um toquezito mas foi a frente coiza pouca...mas o airbag n tem luz acesa.
Enviado do meu GT-I9505 através de Tapatalk
