Primeira utilização vag-com v912
boas, depois da 1ª utilizaçao do vag com v912, aparecem-me os seguintes erros:
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H13 4230
Revision: 91H13423 Serial number: 0036M0G5K37$
Coding: 0030612
Shop #: WSC 06335 000 00000
2 Faults Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Time Indication: 0
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 8
Reset counter: 39
Time Indication: 0
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 Q HW: 8E0 035 192 Q
Component: RNS-E HIGH EU H73 0550
Revision: 02S Serial number: AUZBZ7G1100248
Coding: 0301117
Shop #: WSC 00000 785 00200
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 3
Time Indication: 0
Date: 2009.03.06
Time: 13:53:19
Freeze Frame:
Voltage: 12.50 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 3
Time Indication: 0
Date: 2009.03.06
Time: 13:30:27
Freeze Frame:
Voltage: 12.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00878 - Connection to Speaker Front Left
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Time Indication: 0
Date: 2010.09.17
Time: 18:42:16
00879 - Connection to Speaker Front Right
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Time Indication: 0
Date: 2010.09.17
Time: 18:42:16
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 CJ
Component: Komfortgerát TBF 4135
Coding: 07018
Shop #: WSC 06335
Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0606
Part No: 8E1959802H
Component: Tõrsteuer.BF BRM 0606
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01559 - Drivers Door
57-10 - Electric Circuit Failure - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301117
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 3
Time Indication: 0
Date: 2009.03.06
Time: 13:53:19
Freeze Frame:
Voltage: 12.50 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 3
Time Indication: 0
Date: 2009.03.06
Time: 13:30:27
Freeze Frame:
Voltage: 12.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Time Indication: 0
Date: 2010.09.17
Time: 18:42:16
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Time Indication: 0
Date: 2010.09.17
Time: 18:42:16
Posso apaga-los e voltar a fazer scan?
Porque se forem mesmo erros, voltam a aparecer ou não?
Cumps.
Ola estou com um problema!
Comprei um cabo vag-com 912
quando o encaixo na porta USB do computador com win XP ele avisa que encontrou um cabo Ross Tech Hex Usb
tento instalar os drivers que vieram no cd e nada apenas não encontra drivers nenhuns.
Alguem me pode ajudar?
Gostaria de falar com alguem pois estou a dar em maluco e ja a pensar que me venderam um cabo estragado.
Se poderem enviar-me o numero de telefone preferencia 91 e ligo .
Nuno
