boa tarde comprei á alguns dias um cabo vag-com e fiz o meu primeiro scan.
apareceu-me isto e como nao percebo nada preciso de ajuda sera que tem algum erro ou esta tudo bem?
se alguem me puder ajudar agradecia
obrigado
Sunday,26,March,2017,13:37:19:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Mileage: 234050km-145431mi Repair Order:
Chassis Type: 8D - Audi A4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 234050km/145431miles
Part No: 038 906 018 S
Component: 1,9l R4 EDC 00SG 1621
Coding: 00002
Shop #: WSC 06335
VCID: 26431013C212D62ECEF-4A3A
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
00553 - Mass Air Flow Sensor (G70)
27-00 - Implausible Signal
00626 - Glow Plug Indicator Light (K29)
31-00 - Open or Short to Ground
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Shop #: BB 24548
VCID: 5EB378F3DAC24EEEC6F-5072
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOöAU
Shop #: öAö
VCID: 29591B2FD30CF956E3D-2566
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 L
Component: Airbag 7 Audi 0503
Coding: 00106
Shop #: WSC 06335
VCID: 3F8DA5773D8867E6AD9-5072
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 880 M
Component: B5-KOMBIINSTR. VDO D02
Coding: 04140
Shop #: WSC 00222
VCID: 3C77D27B2C9E7CFE88B-5000
Subsystem 1 - Part No: IMMO
Component: IDENTNR: AUZ7Z0V0282832
IMMO-IDENTNR: AUZ7Z0V0282832
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 L
Component: ZV-Pumpe D04
Coding: 00000
Shop #: WSC 06335
VCID: 3E73D8733A826EEEA6F-4EB0
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
01360 - Switch for Anti-Theft Alarm; Open
00991 - Interior Lights
28-00 - Short to Plus
Sunday,26,March,2017,13:47:26:62939
Coding: 00002
Shop #: WSC 06335
Readiness: N/A
Shop #: BB 24548
Address 08: Auto HVAC Labels: None
Part No: 8L0 820 0 ö
Component: 8Lö8L08L08200ö8
Shop #: 8L08ö8L08
VCID: A24B8C032E3AAA0E227-2580
Note: Excessive Comm Errors
Coding: 00106
Shop #: WSC 06335
Coding: 04140
Shop #: WSC 00222
Coding: 00000
Shop #: WSC 06335
VCID: 3E73D8733A826EEEA6F-4E42
obrigado
Coding: 00002
Shop #: WSC 06335
3 Faults Found:
P1570 - 35-00 -
Readiness: N/A
Shop #: BB 24548
Shop #: öAö
No Faults Found
Coding: 00106
Shop #: WSC 06335
Coding: 04140
Shop #: WSC 00222
Coding: 00000
Shop #: WSC 06335
4 Faults Found:
35-00 - -
Coding: 00002
Shop #: WSC 06335
Readiness: N/A
Shop #: BB 24548
Shop #: 8L08ö8L08
Coding: 00106
Shop #: WSC 06335
Coding: 04140
Shop #: WSC 00222
Coding: 00000
Shop #: WSC 06335
