pro-kit ou sportline
  • Thread starter Thread starter ktm
boas tenho um a3 8l tou a pensar rebaixar 30mm sabem me ajudar qual a diferença entre eiback-prokit e sportline
A diferença tá no rebaixamento.
as pro-kit rebaixam 1.0"- 1.5" (tens de converter para mm mas acho que é 30-35mm)
as sporline rebaixam 1.7"-2.3".
Ou seja, para o que tu queres as mais aconselhadas são as pro-kit.
Pro-Kit
:arrow: Performance Spring Kit for The Look That Performs
:arrow: Lower Center of Gravity -- Lowers Vehicle 1.0" - 1.5"
-- For a More Aggressive Stance
:arrow: Progressive Spring Design for High Performance
Handling and Excellent Ride Quality
:arrow: Million Mile Warranty
The Eibach Pro-Kit is the perfect answer for most frequently-driven street cars. It´s our legendary spring system that dramatically improves both a vehicle´s performance and appearance.
Pro-Kit lowers your car´s center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach Pro-Kit is the finishing touch to a winning recipe for performance. Pro-Kit also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Every Eibach Pro-Kit is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, Pro-Kit provides the ultimate balance to take your passion for driving to a whole new level.
Sportline
:arrow: Extreme Performance Meets Extreme Style
:arrow: Race-Car Like Handling
:arrow: Lowers Vehicle 1.7" - 2.3"
:arrow: Excellent Ride Quality
:arrow: Part of the Eibach Sport-System
Eibach Sportline is the extreme-performance spring set created for the extreme enthusiast—the one who craves a race-car attitude for maximum street performance—with the lowest possible drop, but with the exceptional ride quality you expect from Eibach.
Engineered with the same care as our Pro-Kit springs, Eibach Sportline springs achieve legendary handling by aggressively lowering your car’s center of gravity, using our precision—engineered progressive spring rates.
By radically lowering your car’s center of gravity, our Sportline springs dramatically reduce squat during acceleration, body roll in corners and nose-dive under braking. By using our proprietary, progressive spring design, our Sportline springs provide the ultimate balance between high performance, extreme lowering and comfortable ride quality. When combined with today’s wild 18", 19" or 20" wheels and tires, the result is a car that handles just as white-hot as it looks
