problemas na a4 e respetivo log
Boas, aqui deixo um log da A4 que anda com estes problemas, alguém me pode ajudar a compreender este log. :eek:
Audi a4 2.0tdi 140
Sintomas da bicha:
-LUZ air bag acesa
-falhanços ás vezes
-luz de lampada fundida acesa por ter leds na matrícula
Saturday,19,November,2011,13:55:20:10074
VCDS Version: Beta 11.2.0
Data version: 20110305
techno321 house
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E Mileage: 193790km/120415miles
Address 01: Engine Labels: 03G-906-016-BLB.lbl
Part No SW: 03G 906 016 GN HW: 028 101 211 3
Component: R4 2,0L EDC 0000SG 9618
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 71528 136 80668
VCID: 75E5E5E76701
1 Fault Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 16.2°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
Component: ESP8 front H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
Shop #: WSC 06325 000 00000
VCID: 2647F2ABEA27
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AJ
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 69DDB9973BB9
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul ECE 0304
Coding: 10121
Shop #: WSC 06325
VCID: 3B7133DF01A5
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036M001MG7Y
Coding: 0033622
VCID: 3B7133DF01A5
2 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 99
Mileage: 1048575 km
Time Indication: 0
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 1
Fault Frequency: 15
Mileage: 1048575 km
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01012
Shop #: WSC 06325
VCID: 43814B3F7955
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 D HW: 8E0 920 931 D
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006141
Shop #: WSC 73249 020 01196
VCID: 295DF997FB39
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
VCID: 356525E72781
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 BG
Component: Komfortgerát T85 2431
Coding: 07024
Shop #: WSC 06325
VCID: 77F9EFEF7D0D
Subsystem 1 - Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0205
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 B
Component: Dynamische LWR H01 0020
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 397D29D70B99
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 D
Component: concert II GRO 0004
Coding: 01031
Shop #: WSC 34894
VCID: 285BFC93E033
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 D HW: 8P0 862 335 D
Component: FSE_255x BT H18 0050
Revision: 00000001 Serial number: 00000000161471
Coding: 0000511
Shop #: WSC 34894 142 82618
VCID: 37792FEF3D8D
o problema é que estes são canbus, na B7 dizem que só de resistências, é verdade?
Vou analisar o resto. Obrigado amigo.
se so dão com resistencias nesse modelo ja ñ sei, mas se os que tens são canbus entao tenta com resistencias..
sempre as ordens ;)
Quanto ao aviso de lampada fundida por causa dos Leds na matricula, já sabias que isso ia aconteçer, e em B7 nem com leds CANBUS te safas. A unica solução é umas resistênçias.
Problema de airbag:
Entra no módulo de AIRBAGS e depois em ADAPTATION e depois clicas em LEARNED VIN e metes o código que o vagcom te indica e pronto.
O segundo erro, salvo é na ficha do airbag, no banco do passageiro. Desligar ficha, limpar muito bem limpo e voltar a ligar e depois claro apagar erro com o vagcom.
A falha pode ser relaçionado com a ficha do injector Nº 3. Ou desmontas a régua dos injectores e limpas as fichas e os pinos, ou metes uma régua nova.
na falha da injeção parece que o erro é uma vela, já tive uma avaria igual e vinha daí o problema, mas era no cilindro 1, poderá ser a vela também? Ou virar prós injetores?
Estou com um bocado de pressão a altas mas isso deve ser a n75, chega aos 235 super depressa, depois parece que corta, o chipador diz que não é eletrónico o erro.
Pois agora desde que meti os leds é um pivete na zona da tampa da mala, parece agua em brasa ou fios quentes sei lá.
n tive tempo de desforrar aquilo ainda
pois esse erro do vin acho que já fiz isso uma vez, lá vou ter de fazer mais uma, ainda não percebi de onde vem aquilo...
obrigado amigo jimy
Audi a4 2.0tdi 140
Sintomas da bicha:
-LUZ air bag acesa
-falhanços ás vezes
techno321 house
69 75 76 77
Coding: 0000072
VCID: 75E5E5E76701
1 Fault Found:
17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault Vela
P0673 - 000 - -
Freeze Frame:
RPM: 882 /min
Torque: 34.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11000100
Temperature: 16.2°C
Bin. Bits: 10110000
Coding: 0004401
VCID: 2647F2ABEA27
Coding: 00000
Shop #: WSC 00000
VCID: 69DDB9973BB9
Coding: 10121
Shop #: WSC 06325
VCID: 3B7133DF01A5
Coding: 0033622
VCID: 3B7133DF01A5
2 Faults Found:
01794 - Control Module - Incorrect Chassis (VIN) Number Modulo provavelmente substituido e não programado
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 99
Mileage: 1048575 km
Time Indication: 0
01218 - Side Airbag Igniter; Passenger Side (N200) Detonador do air-bag, provavelmente mau contacto nas fichas
Freeze Frame:
Fault Priority: 1
Fault Frequency: 15
Mileage: 1048575 km
Time Indication: 0
Coding: 01012
Shop #: WSC 06325
VCID: 43814B3F7955
Coding: 0006141
VCID: 295DF997FB39
VCID: 356525E72781
Coding: 07024
Shop #: WSC 06325
VCID: 77F9EFEF7D0D
Coding: 0000005
VCID: 397D29D70B99
Coding: 01031
Shop #: WSC 34894
VCID: 285BFC93E033
Coding: 0000511
VCID: 37792FEF3D8D
Espero não ter metido Agua!...:eek: :D
O airbag não é programado. Ou ele trocou e ainda tem o Nº de chassi do ultimo carro, ou por alguma razão perdeu o nº de chassi do carro dele.. Por vezes aconteçe...
pareceu-me tudo bem, relativamente ao airbag vim a descobrir que levou um porradão de traseira (na alemanhã) que entortou um bocado a longarina atrás e levou um choques novo, mas nada de grave não gasta pneu nem nada, não sei se pode estar relacionado com os erros de airbag
obrigado amigo jimy
aqui em relação ao desvio de pressões e cheiro na zona da tampa da mala, o que podem dizer :eek:
obrigado, já fiquei esclarecido.
jimy qual é o modelo da resistência e como os montas(em que zona os soldas), se pudesses dizer. obg
