Relantim incerto
ontem a noite reparei que o carro de um amigo meu tinha um relantim incerto por vezes ate tinha picos de 1000rpm.
Liguei ao Vag-com deu-me nisto:
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Controller:
Note: Can't Synch Baud Rate
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 G
Component: ABS 5.7 FRONT V30
Coding: 00044
Shop #: WSC 82555
1 Fault Found:
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
2 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
000 - -
01274 - Air Flow Flap Positioning Motor (V71)
000 - - - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 16524
Shop #: WSC 06402
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 820 H
Component: KOMBI+WEGFAHRSP VDO V10
Coding: 00145
Shop #: WSC 00000
VSSZZZ6LZ3R170687 SEZ7Z0C1928533
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 60 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 Q
Component: LenkhilfeTRW V250
Coding: 00121
Shop #: WSC 06402
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 2G Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
Address 56 -------------------------------------------------------
Controller: 6L0 035 156
Component: seat s04 GRO 1 88
Coding: 00401
Shop #: WSC 06402
End -------------------------------------------------------
Alguem me pode ajudar?
01314 - Engine Control Module: No Communications
Possible Causes:
-CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
-Fault(s) stored in Engine Control Module
-Engine Control Module recently flashed or re-mapped
Possible Solutions:
-Check CAN-Databus Wiring/Connectors from/to Engine Control Module
-Check Measuring Value Blocks (MVB)
-Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01272 - Positioning Motor for Central Flap (V70): Faulty
Possible Causes:
-Wiring/Connectors from/to Positioning Motor for Central Flap (V70) falty
-Positioning Motor for Central Flap (V70) blocked
-Positioning Motor for Central Flap (V70) faulty
Possible Solutions:
-Check Positioning Motor for Central Flap (V70)
-See Measuring Value Blocks (MVB)
-Perform Output Test
-Perform Basic Setting
-Check/Repair Wiring and Connectors
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes:
-Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
-Positioning Air Flow Flap Positioning Motor (V71) blocked
-Positioning Air Flow Flap Positioning Motor (V71) faulty
Possible Solutions:
-Check Air Flow Flap Positioning Motor (V71)
00929 - Locking Module for Central Locking; Front Passenger Side (F221): Implausible Signal
Possible Symptoms:
-Door Locks not working properly
Possible Causes:
-Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221) faulty
-Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221) faulty
-Door Lock Mechanics are stiff/partially seized
-Locking Module for Central Locking; Front Passenger Side (F221) faulty
Possible Solutions:
-Check Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221)
-Check Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221)
-Check Door Lock Mechanics/Operation
-Check Locking Module for Central Locking; Front Passenger Side (F221)
Espero que seja uma ajuda.. alguns sao faceis de perceber..
acho que podes mostrar isto a um mecanico que perceba de electronica VAG..
