Boas pessoal, recentemente fiz um scan ao argolas e apareceram estes erros, se alguém me puder dar uma ajuda a decifra-los agradecia.
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 06435 000 00000
1 Fault Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14949
Shop #: WSC 06435
1 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Coding: 0019970
1 Fault Found:
Coding: 14949
Shop #: WSC 06435
1 Faults Found:
35-00 - -
1 Fault Found:
00-00 - -
