sinal TMC
tirar o sinal , como assim ?
se não tens tmc , logo não tens sinal :S
ou então nao tou a perceber onde queres chegar
edit - ups , afinal dá :S :oops: :oops: :oops: peço desculpa pela info que dei errada
http://www.nav-plus.com/programming.html
Connect VagCom and go to Module 37, Navigation. You use the "Adaption - 10" function of VAGCom to do this
Canal 6 - TMC Coding (D-Navi)
0 This will disable TMC. Use 0 if you do not have a TMC on your unit to prevent a startup error being displayed when you turn on your Nav Plus. Traffic button will be disabled.
1 Sets TMC to use radio source. (Useless in N.A.)
2 Sets TMC to use telephone source. (Useless in N.A.)
3 Sets TMC to use radio and telephone source. (Useless in N.A.)
Resumindo, 0 (zero) no canal 6 e desactivas essa mensagem ;)
